Featuring three-zone 16.8M color customizable backlighting and an 8,200 DPI laser sensor, the Corsair Gaming M65 RGB gaming mouse optimizes hardcore play with a tactile high-mass scroll wheel, eight easily programmable buttons, a dedicated sniper button, top-grade Omron switches, and a solid, weight-tuned aluminum base for a precisely balanced, professional feel.
Comfortable for Hours of Game Play
Carefully selected materials and superior ergonomics, combined with precise tracking and advanced customization, help M65 cross that point where it doesn’t feel like a mouse, but like an extension of your hand.
Beautiful but deadly
The M65 RGB is based on the award-winning M65. It’s upgraded with three-zone backlighting that lets you choose from 16.8 million colors for virtually infinite customization.
Highly accurate tracking
The M65 RGB has an 8,200 DPI gaming-grade laser sensor for pixel-precise tracking. It’s custom tuned to give great performance, even on not-so-great surfaces.
Easy configuration and onboard profile storage
The Corsair Utility Engine (CUE) makes it easy to set up button mapping and other parameters for each of your favorite games. And, you can save a gaming profile directly to your M65 RGB and take it with you.
Selectable response time
Tune the performance for your desktop surface by choosing between 1000Hz, 500Hz, 250Hz, or 125Hz (1ms, 2ms, 4ms or 8ms).
High-Mass scroll wheel
The solid metal, rubberized scroll wheel doesn't just feel great — it gives you the precision you need when selecting weapons. Precise tactile feedback and accuracy help make sure that you select the right weapon every time.
The Corsair Utility Engine (CUE) makes it easy to set up button mapping and other parameters for each of your favorite games. And, you can save a gaming profile directly to your M65 RGB and take it with you. -
High-mass scroll wheel
The solid metal, rubberized scroll wheel doesn't just feel great - it gives you the precision you need when selecting weapons. Precise tactile feedback and accuracy help make sure that you select the right weapon every time. -
Dedicated programmable sniper button
Quickly switch sensor resolution when you need extreme accuracy in FPS games. It's not just for when you've selected a long-range weapon - it's an indispensible feature any time you need to quickly switch to ultra-precise control. -
Aluminum unibody design
A unibody aluminum frame is the secret behind its low weight, high rigidity, and optimal mass distribution. -
Adjustable weight system
Three adjustable tuning zones allow you to customize the weight of your M65 RGB to give it just the exact feel you want. -
PTFE glide pads
The M65 RGB is designed with low-friction contact points for swift, precise movement with minimal effort.
- CORSAIR Gaming M65 RGB - mouse - USB - black
- Mouse
- Connectivity Technology
- Wired - USB
- Black
- 7.2 cm x 11.8 cm x 3.9 cm
- 115 g
- Localisation
- Europe
- Movement Detection Technology
- Laser
- Buttons Qty
- 8
- Movement Resolution
- 8200 dpi
- Performance
- Realtime sensitivity switching 50 - 8200 dpi, 125/250/500/1000 reports per second, 1/2/4/8 ms response time
- Programmable buttons, adjustable weight, polytetrafluoroethylene (PTFE) feet, built-in flash memory, sniper button, braided cable, rubberised scroll wheel, aluminium body, OMRON switches, 16.8 million multi-colour illumination, Corsair Utility Engine (CUE), 3-zone illumination
- Cable Length
- 1.8 m
- OS Required
- Microsoft Windows Vista / 7 / 8
- 2-year warranty
- Mouse
- 7.2 cm
- 11.8 cm
- 3.9 cm
- 115 g
- Black
- Localisation
- Europe
Input Device
- Wired
- Interface
- USB
- Laser
- Buttons Qty
- 8
- 8200 dpi
- Performance
- Cable Length
- 1.8 m
- 1 x USB 2.0 - 4 pin USB Type A
- OS Required
- Limited warranty - 2 years
