The Vengeance M65 laser mouse is a finely-honed FPS gaming tool. It offers an 8200 DPI sensor for superior tracking, a dedicated sniper button that lets you switch resolution for extremely accurate shots, and an adjustable weight system for a custom fit to the way you play.
Highly accurate tracking
If you're good at gaming, you're probably playing against opponents who are just as good. M65 provides the reliable response you need to give you a competitive edge. -
Advanced customization and control
Because winning isn't just about reflexes and accuracy - you need quick weapon selection and the ability to set up your mouse to do exactly what you need it to do. -
Comfortable for hours of game play
Carefully selected materials and superior ergonomics, combined with precise tracking and advanced customization, help M65 cross that point where it doesn't feel like a mouse, but like an extension of your hand. -
Dedicated programmable sniper button
Quickly switch sensor resolution when you need extreme accuracy in FPS games. It's not just for when you've selected a long-range weapon - it's an indispensable feature any time you need to quickly switch to ultra-precise control. -
Onboard profile storage
Once you've set up your button configuration and other parameters for each of your favorite games, you can quickly toggle between profiles directly from the M65. Since they're stored onboard, you can take your profiles with you. -
Aluminum unibody design
With a long history of building enthusiast-grade memory and components, Corsair's earned a reputation for quality, compatibility, and performance. Need help? Corsair's available by phone call, email or web forum. -
Adjustable weight system
Three adjustable tuning zones allow you to customize the weight of your M65 to give it just the exact feel you want. -
High-mass scroll wheel
The solid metal, rubberized scroll wheel doesn't just feel great - it gives you the precision you need when selecting weapons. Precise tactile feedback and accuracy help make sure that you select the right weapon every time.
- CORSAIR Vengeance M65 FPS Gaming - mouse - USB - black
- Mouse
- Connectivity Technology
- Wired - USB
- Black
- Localisation
- Europe
- Movement Detection Technology
- Laser
- Buttons Qty
- 8
- Movement Resolution
- 8200 dpi
- Performance
- 125/250/500/1000 reports per second, 1/2/4/8 ms response time
- Programmable buttons, adjustable weight, switchable resolution, polytetrafluoroethylene (PTFE) feet, built-in flash memory, soft-touch surface, sniper button, rubberised scroll wheel, aluminium body
- OS Required
- Microsoft Windows Vista / XP / 7 / 8
- 2-year warranty
- Mouse
- Black
- Localisation
- Europe
Input Device
- Wired
- Interface
- USB
- Laser
- Buttons Qty
- 8
- 8200 dpi
- Performance
- 1 x USB - 4 pin USB Type A
- OS Required
- Limited warranty - 2 years
