Corsair Gaming KATAR Mouse - Black
Quicklinx: BQZ9WS00 Mfr#: CH-9000095-EU
Corsair Katar is the gaming mouse in its pure form. An 8,000 DPI optical sensor, a compact and light weight design tuned for exceptional comfort and feel, and configuration settings designed by the world's top players deliver the essentials of pure gaming performance for pro gamers or anybody who wants to beat pro gamers.
  • 8,000 DPI optical sensor
    It delivers extreme accuracy for FPS and MOBA gaming. Zero acceleration provides precise tracking for headshots or champion kills.
  • Zero lag interface
    The polling rate pushes the limits of the USB protocol for imperceptible lag.
  • On-the-fly DPI tuning
    Instantly adapt your mouse speed to the situation for total command of any environment.
  • Four programmable buttons
    Take control with extensive customization - anything from simple remaps to complex macros.
  • Ambidextrous shape
    Optimized textured rubber sides grips for left and right handed players.
CORSAIR Gaming Katar - mouse - USB
Mouse
Wired - USB
6.39 cm x 11.07 cm x 3.84 cm
85 g
Europe
Movement Detection Technology
Optical
Buttons Qty
4
Movement Resolution
8000 dpi
Performance
125/250/500/1000 reports per second, realtime sensitivity switching 100 - 8000 dpi
Programmable buttons, rubber side grips, polytetrafluoroethylene (PTFE) feet, built-in flash memory, red backlighting, Corsair Utility Engine (CUE)
Cable Length
1.8 m
Microsoft Windows 7 / 8 / 10
Mouse
6.39 cm
11.07 cm
3.84 cm
85 g
Europe
Input Device
Wired
USB
Optical
Buttons Qty
4
Movement Resolution
8000 dpi
Performance
Cable Length
1.8 m
1 x USB - 4 pin USB Type A
