Corsair Katar is the gaming mouse in its pure form. An 8,000 DPI optical sensor, a compact and light weight design tuned for exceptional comfort and feel, and configuration settings designed by the world's top players deliver the essentials of pure gaming performance for pro gamers or anybody who wants to beat pro gamers.
It delivers extreme accuracy for FPS and MOBA gaming. Zero acceleration provides precise tracking for headshots or champion kills. -
Zero lag interface
The polling rate pushes the limits of the USB protocol for imperceptible lag. -
On-the-fly DPI tuning
Instantly adapt your mouse speed to the situation for total command of any environment. -
Four programmable buttons
Take control with extensive customization - anything from simple remaps to complex macros. -
Ambidextrous shape
Optimized textured rubber sides grips for left and right handed players.
- CORSAIR Gaming Katar - mouse - USB
- Mouse
- Connectivity Technology
- Wired - USB
- 6.39 cm x 11.07 cm x 3.84 cm
- 85 g
- Localisation
- Europe
- Movement Detection Technology
- Optical
- Buttons Qty
- 4
- Movement Resolution
- 8000 dpi
- Performance
- 125/250/500/1000 reports per second, realtime sensitivity switching 100 - 8000 dpi
- Programmable buttons, rubber side grips, polytetrafluoroethylene (PTFE) feet, built-in flash memory, red backlighting, Corsair Utility Engine (CUE)
- Cable Length
- 1.8 m
- OS Required
- Microsoft Windows 7 / 8 / 10
- 2-year warranty
- Mouse
- 6.39 cm
- 11.07 cm
- 3.84 cm
- 85 g
- Localisation
- Europe
Input Device
- Wired
- Interface
- USB
- Optical
- Buttons Qty
- 4
- 8000 dpi
- Performance
- Cable Length
- 1.8 m
- 1 x USB - 4 pin USB Type A
- OS Required
- Limited warranty - 2 years
