Your basket is empty
Corsair Gaming K70 RGB RAPIDFIRE Mechanical Gaming Keyboard Cherry MX
Quicklinx: C866WS00 Mfr#: CH-9101014-UK
Wired / Wireless: Wired
Colour: Anodised brushed aluminium
Compatibility: PC
Stock Status: Pre-order
Pre-order
£130.01 ex VAT
£156.01 inc VAT
The K70 RGB RAPIDFIRE gaming keyboard has Cherry MX Speed RGB switches backed by a lightweight, durablealuminum frame. Advanced lighting control and large font keycaps deliver dynamic, vibrant multi-color backlighting. Harness the power of CUE for sophisticated macro programming and dramatic lighting effects and animations. 100% anti-ghosting with full key rollover on USB helps ensure accuracy, so every keystroke translates directly into accuratengameplay. The USB pass-through port is positioned for uninterrupted game play and ready for your mouse or wireless headset adapter. Contoured, textured FPS and MOBA key sets keep you in control, and the Cherry MX Speed RGB switches give you linear response and fast actuation
Corsair Gaming K70 RGB RAPIDFIRE Mechanical - keyboard - UK
Keyboard
Backlit
RGB
USB
Layout
Hot Keys Qty
6
Hot Keys Function
Multimedia, volume, macros buttons, Windows key lock
Numeric Keypad
43.6 cm x 16.5 cm x 3.8 cm
1.2 kg
2 years warranty
Keyboard
Backlit
RGB
USB
Input Device
Hot Keys Qty
6
Hot Keys Function
Layout
Keyboard Technology
Mechanical
Key Switch Type
CHERRY MX Speed switches
Palm Rest
Numeric keypad
43.6 cm
16.5 cm
3.8 cm
1.2 kg
FPS and MOBO keycap sets
Microsoft Windows Vista / 7 / 8 / 10
Compatibility: PC
Brand: Corsair Gaming
Price Range Ex VAT: 100 - 150
