Your basket is empty
Corsair Gaming K70 RGB Cherry MX Brown Switches Mechanical Keyboard
Quicklinx: 9RWJWS00 Mfr#: CH-9000065-UK
Recommended Use: Gaming
Type: Keyboard
Wired / Wireless: Wired
Colour: Anodised black brushed aluminium
Compatibility: PC
Hurry, only 1 left in stock!
£152.03 ex VAT
£182.43 inc VAT
Legendary mechanical gaming keyboard performance with virtually unlimited customization
The Corsair Gaming K70 RGB mechanical gaming keyboard begins with the durability, styling and responsiveness of the legendary Vengeance K70, and adds multicolor per-key backlighting for virtually endless lighting combinations. It's built with 100% Cherry MX Brown key switches that provide light tactile feedback for fast performance and precise timing. Each key can be individually programmed to display any of 16.8M colors and multiple brightness levels for a level of customization never before seen in a mechanical keyboard. Full key rollover and anti-ghosting ensure accurate gameplay. And, the K70 RGB is built to last, with a black anodized brushed aluminum finish that's sturdy and lightweight.
  • 100% Cherry MX Brown mechanical key switches: light tactile feedback for fast performance and precise timing
  • Multi-color per-key backlighting for unlimited game customization: customize each key from a palette of 16.8 million colors and multiple illumination levels
  • Aircraft-grade anodized brushed aluminum frame: high durability, high rigidity, and low weight
  • Contoured, textured WASD and 1-6 keycaps and detachable soft-touch wrist rest: optimized for FPS gaming comfort and control
  • 100% anti-ghosting with 104 key rollover on USB: Reliably accurate performance no matter how fast you are
Corsair Gaming K70 RGB Mechanical - keyboard - UK
Keyboard
USB
Layout
Hot Keys Qty
6
Hot Keys Function
Volume, play/pause, stop, previous track, next track
Detachable wrist rest, anti-ghosting, Windows Lock key, selectable report rate, individual key LED backlight, Cherry MX Brown technology, ARM Cortex 32-bit processor, braided fibre cable, 104-key rollover, any key macros, Panasonic display controller, Corsair Utility Engine (CUE), onboard memory
43.8 cm x 16.3 cm x 2.4 cm
1.24 kg
2 years warranty
Keyboard
USB
Input Device
Hot Keys Qty
6
Hot Keys Function
Layout
Keyboard Technology
Mechanical
43.8 cm
16.3 cm
2.4 cm
1.24 kg
1 x USB cable
Microsoft Windows 7, Microsoft Windows Vista, Windows 8
Type: Keyboard
Compatibility: PC
Cherry MX Switch Colour: Brown
Brand: Corsair Gaming
Stock Status: Clearance
Price Range Ex VAT: 150 - 300
