The Corsair Gaming K70 is a fully mechanical gaming keyboard with an anodized, brushed aluminum chassis for a professional-grade look and feel. Contoured, textured FPS keys keep you in control if shooters are your game. It's built with Cherry MX switches, and key by key customizable backlighting lets you illuminate your key bindings. Fully anti-ghosting with 104 key rollover on USB helps ensure accuracy, so every keystroke translates directly into accurate gameplay. The all-important WASD and 1-6 keys are contoured and textured, so you can find them fast, and enjoy fast gaming action with less chance of your fingers missing their mark. You can program backlighting for each key independently, so you can set up a custom-lit key binding and save it to onboard memory. Not only is the K70 a remarkable gaming keyboard - it looks amazing, too. The brushed aluminum frame is black anodized for an impressive look, and the brilliant red backlighting gives it the unmistakable look of serious gaming machinery.
Cherry MX mechanical key switches
You get smooth, linear key response for ultra fast double and triple taps without the audible click. -
Key-by-key customizable backlighting
Bright blue LEDs with adjustable brightness and key-by-key programmability to light up just the keys you need. It's great for illuminating your key bindings for each game. It's saved directly to the K70 onboard memory, so you can take your light maps with you. -
Anodized, brushed aluminum chassis
The K70 frame has a professional-grade look and feel, plus the rugged durability you need for hours of gaming. -
Anti-Ghosting with 104 key rollover on USB
Every keystroke translates into accurate gameplay - even when multiple keys are pressed. There's no signal degradation, and it keeps up with you, no matter how fast you play. -
Contoured, textured WASD and 1-6 keycaps
Keep your eyes on the action with easy to locate FPS keys. An extra set of standard typing keycaps and a keycap replacement tool are provided for general typing. -
Easy-access dedicated multimedia controls
You don't just play games - you play music and video, too. Play, stop, pause, skip tracks and adjust volume directly from the K70. -
USB pass-through
An extra USB connector is provided. It's great for attaching a Corsair Gaming mouse or headset.
- CORSAIR Gaming K70 Mechanical - keyboard - UK - black
- Keyboard
- Backlit
- Blue
- Interface
- USB
- Connectivity Technology
- Wired
- Localization and Layout
- UK
- Keys Qty
- 104
- Hot Keys Qty
- 6
- Hot Keys Function
- Multimedia
- Numeric Keypad
- Detachable wrist rest, Windows Lock key, Contoured, Textured WASD and 1-6 Keycaps, USB pass-through, 1000Hz polling rate, 104-key rollover, onboard memory
- Gaming
- Key Switch Type
- CHERRY MX Red
- Black
- 43.8 cm x 16.3 cm x 2.4 cm
- 1.24 kg
- 2-year warranty
- Keyboard
- Backlit
- Blue
- Interface
- USB
Input Device
- Keys Qty
- 104
- Hot Keys Qty
- 6
- Hot Keys Function
- Multimedia
- UK
- Keyboard Technology
- Mechanical
- Key Switch Type
- CHERRY MX Red
- Gaming
- Palm Rest
- Detachable wrist rest, Windows Lock key, Contoured, Textured WASD and 1-6 Keycaps, USB pass-through, 1000Hz polling rate, 104-key rollover, onboard memory numeric keypad
- 43.8 cm
- 16.3 cm
- 2.4 cm
- 1.24 kg
- Black
- OS Required
- Microsoft Windows Vista / XP / 7 / 8
- Limited warranty - 2 years
