Your basket is empty
Corsair Gaming K70 Red (Blue LED) Gaming Keyboard
Quicklinx: BP02WS00 Mfr#: CH-9000117-UK
The Corsair Gaming K70 is a fully mechanical gaming keyboard with an anodized, brushed aluminum chassis for a professional-grade look and feel. Contoured, textured FPS keys keep you in control if shooters are your game. It's built with Cherry MX switches, and key by key customizable backlighting lets you illuminate your key bindings. Fully anti-ghosting with 104 key rollover on USB helps ensure accuracy, so every keystroke translates directly into accurate gameplay. The all-important WASD and 1-6 keys are contoured and textured, so you can find them fast, and enjoy fast gaming action with less chance of your fingers missing their mark. You can program backlighting for each key independently, so you can set up a custom-lit key binding and save it to onboard memory. Not only is the K70 a remarkable gaming keyboard - it looks amazing, too. The brushed aluminum frame is black anodized for an impressive look, and the brilliant red backlighting gives it the unmistakable look of serious gaming machinery.
Corsair Gaming K70 Mechanical - keyboard - UK
Keyboard
Backlit
Blue
USB
Layout
Keys Qty
104
Hot Keys Qty
6
Hot Keys Function
Multimedia
Numeric Keypad
Detachable wrist rest, Windows Lock key, Contoured, Textured WASD and 1-6 Keycaps, USB pass-through, 1000Hz polling rate, 104-key rollover, onboard memory
43.8 cm x 16.3 cm x 2.4 cm
1.24 kg
2 years warranty
Keyboard
Backlit
Blue
USB
Input Device
Keys Qty
104
Hot Keys Qty
6
Hot Keys Function
Multimedia
Layout
Keyboard Technology
Mechanical
Key Switch Type
CHERRY MX Red switches
Palm Rest
Detachable wrist rest, Windows Lock key, Contoured, Textured WASD and 1-6 Keycaps, USB pass-through, 1000Hz polling rate, 104-key rollover, onboard memory numeric keypad
43.8 cm
16.3 cm
2.4 cm
1.24 kg
Microsoft Windows Vista / XP / 7 / 8
