Corsair Raptor K40 gives you your choice of 16.8 million backlighting colors, programmable G-keys with onboard storage, multimedia controls, and 100% anti-ghosting with full key rollover on USB for fast, accurate gameplay. The customizable backlighting lets you choose your color to match your system or your style, and the six dedicated, programmable G-keys let you quickly access your favorite macros, presets, and key combinations.
The full key matrix anti-ghosting with full key rollover on USB translates into accurate gameplay, even when multiple keys are pressed. And, the easy-access multimedia controls let you play, pause, skip tracks and adjust volume directly from the keyboard.
6.8 million color customizable backlighting
Choose from millions of LED backlighting colors to match your system or your style. -
Full key matrix anti-ghosting with full key rollover on USB
Every keystroke translates into accurate gameplay - even when multiple keys are pressed. -
6 dedicated, programmable G-Keys
Access your favorite macros, presets and key combinations, even during the most intense action. -
On-board profile storage
Stores settings and profiles in the keyboard memory so they work independently of software and on other PCs. -
Easy-access multimedia controls
Play, stop, pause, skip tracks, and adjust volume directly from the keyboard.
- CORSAIR Raptor K40 Gaming - keyboard - UK
- Keyboard
- Backlit
- Interface
- USB
- Connectivity Technology
- Wired
- Localization and Layout
- UK
- Hot Keys Qty
- 7
- Hot Keys Function
- Mute, play/pause, stop, previous track, next track, volume -, volume +, Windows key lock
- Numeric Keypad
- 2-year warranty
- Keyboard
- Backlit
- Interface
- USB
Input Device
- Hot Keys Qty
- 7
- Hot Keys Function
- UK
- Keyboard Technology
- Rubber dome
- Numeric keypad
- OS Required
- Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Windows 8
- Limited warranty - 2 years
