You get 2.4GHz wireless freedom at up to 40 feet, and ten hours of uninterrupted gaming at a time. Genuine Dolby 7.1 surround gives you lethally accurate positional audio, and the 50mm neodymium drivers produce staggering bass, highs, and dynamic range. Marathon gaming sessions are easy with the microfiber-wrapped earpads, and you'll be heard loud and clear with the unidirectional noise-cancelling microphone.
Genuine Dolby 7.1 surround delivers lethally accurate positional audio. It accurately reproduces multi-channel gaming audio for precise situational awareness and the competitive edge you can only get through positional audio. It also helps reduce "headphone fatigue," which is essential if you play competitively or if you just enjoy playing for hours at a time.
Oversized 50mm neodymium drivers bring the action to life with brilliant range and precision. They greatly reduce the overloading and distortion that can occur with gaming headsets that use smaller drivers that aren't up to the task. You'll get more accurate sound reproduction, particularly for the all-important low-frequency effects.
Enjoy legendary audio with zero hassle
You get 2.4GHz wireless freedom at up to 40 feet, and ten hours of uninterrupted gaming at a time. Genuine Dolby 7.1 surround gives you lethally accurate positional audio, and the 50mm neodymium drivers produce staggering bass, highs, and dynamic range. Marathon gaming sessions are easy with the microfiber-wrapped earpads, and you'll be heard loud and clear with the unidirectional noise-cancelling microphone. -
Epic immersion and true multi-channel audio
Genuine Dolby 7.1 surround delivers lethally accurate positional audio. It accurately reproduces multi-channel gaming audio for precise situational awareness and the competitive edge you can only get through positional audio. It also helps reduce "headphone fatigue," which is essential if you play competitively or if you just enjoy playing for hours at a time. -
Unlock legendary audio
Oversized 50mm neodymium drivers bring the action to life with brilliant range and precision. They greatly reduce the overloading and distortion that can occur with gaming headsets that use smaller drivers that aren't up to the task. You'll get more accurate sound reproduction, particularly for the all-important low-frequency effects. -
Embark on marathon gaming sessions
The comfortable microfiber-wrapped memory foam earpads enable extended play. They provide a reliable fit that conforms to the contours of your head without binding or pinching. -
Take command
The advanced unidirectional noise-cancelling microphone makes you loud and clear, and screens out extraneous noise from outside your game. Said all you have to say? It's easy to flip the mic out of sight when not in use.
- CORSAIR Gaming H2100 Dolby 7.1 Greyhawk - headset
- Product Type
- Headset - 2.4 GHz - wireless
- Recommended Use
- Computer
- Localisation
- Europe
- Headphones Form Factor
- Full size
- Connectivity Technology
- Wireless
- Wireless Technology
- 2.4 GHz radio frequency
- Radio Frequency Range
- 2.4GHz
- Audio Specifications
- Frequency Response 20 - 20000 Hz - Sensitivity 105 dB
- Impedance
- 32 Ohm
- Microphone
- Boom
- Microphone Technology
- Condenser
- 2-year warranty
- Product Type
- Recommended Use
- Computer
- Max Operating Distance
- 12 m
- Localisation
- Europe
Audio Output
- Full size
- Wireless
- 20 - 20000 Hz
- Sensitivity
- 105 dB
- Impedance
- 32 Ohm
- Diaphragm
- 50 mm
- Magnet Material
- Neodymium
Microphone
- Boom
- Condenser
- Sensitivity
- -37 dB
- Impedance
- 2.2 kOhm
- 100 - 10000 Hz
- Audio Input Details
- Uni-directional - 100 - 10000 Hz - Output Impedance 2.2 kOhm
Wireless Link
- 2.4GHz
- Transmission Range
- 12 m
- Connector Type
- USB (4 PIN USB Type A)
- Included Accessories
- USB dongle
- Cable Details
- USB extension cable - 1.5 m , USB charge cable - 1.5 m
- Battery
- Headset battery rechargeable
- Run Time (Up To)
- 10 hour(s)
- Limited warranty - 2 years
