Corsair Gaming H2100 Dolby 7.1 Wireless Gaming Headset
Quicklinx: 9RX9WS00 Mfr#: CA-9011127-EU
Enjoy legendary audio with zero hassle. You get 2.4GHz wireless freedom at up to 40 feet, and ten hours of uninterrupted gaming at a time. Genuine Dolby 7.1 surround gives you lethally accurate positional audio, and the 50mm neodymium drivers produce staggering bass, highs, and dynamic range. Marathon gaming sessions are easy with the microfiber-wrapped earpads, and you'll be heard loud and clear with the unidirectional noise-cancelling microphone.
  • Legendary audio, zero hassle: 2.4GHz wireless freedom up to 40ft + 10 hours of uninterrupted gaming
  • Epic immersion and true multi-channel audio: genuine Dolby 7.1 surround delivers lethally accurate positional audio
  • Unlock legendary audio: Oversized 50mm neodymium drivers bring the action to life with brilliant range and precision
  • Embark on marathon gaming sessions: comfortable microfiber-wrapped memory foam earpads enable extended play.
  • Take command: the advanced unidirectional noise-cancelling microphone makes you loud and clear
    Genuine Dolby 7.1 surround delivers lethally accurate positional audio. It accurately reproduces multi-channel gaming audio for precise situational awareness and the competitive edge you can only get through positional audio. It also helps reduce "headphone fatigue," which is essential if you play competitively or if you just enjoy playing for hours at a time.
    Oversized 50mm neodymium drivers bring the action to life with brilliant range and precision. They greatly reduce the overloading and distortion that can occur with gaming headsets that use smaller drivers that aren't up to the task. You'll get more accurate sound reproduction, particularly for the all-important low-frequency effects.
    The comfortable microfiber-wrapped memory foam earpads enable extended play. They provide a reliable fit that conforms to the contours of your head without binding or pinching.
  • Take command
    The advanced unidirectional noise-canceling microphone makes you loud and clear, and screens out extraneous noise from outside your game.
CORSAIR Gaming H2100 Dolby 7.1 - headset
Headset - 2.4 GHz - wireless
Europe
Headphones Form Factor
Full size
Wireless
Wireless Technology
2.4 GHz radio frequency
Radio Frequency Range
2.4GHz
Sound Effects
7.1 Channel Virtual Surround Sound
Audio Specifications
Frequency Response 20 - 20000 Hz
Impedance
32 Ohm
Microphone
Boom
Microphone Operation Mode
Uni-directional
540 g
Max Operating Distance
12 m
Europe
Audio Output
Full size
Wireless
Wireless Technology
Sound Effects
Frequency Response
20 - 20000 Hz
Impedance
32 Ohm
Dynamic Range
105 dB
Diaphragm
50 mm
Magnet Material
Neodymium
Microphone
Boom
Uni-directional
Sensitivity
-37 dB
Impedance
2.2 kOhm
Frequency Response
100 - 10000 Hz
Audio Input Details
Uni-directional - 100 - 10000 Hz - Output Impedance 2.2 kOhm
Wireless Link
2.4GHz
Transmission Range
12 m
Connector Type
USB (4 PIN USB Type A)
Wireless adapter
Cable Details
USB charge cable - 1.5 m , USB extension cable - 1.5 m
Headphone battery
Run Time (Up To)
10 hours
