Short-body design. Full-sized keys. Mechanical precision.
Vengeance K65 is the compact high-performance mechanical gaming keyboard for travelling gamers or anybody who has limited space. The full-size key spacing won't throw you off your game, and the Cherry MX Red key switches give you smooth, linear key response for ultra fast double and triple taps without the audible click.
There's 100% anti-ghosting with full key rollover on USB for accurate gameplay, no matter how fast you are. And, the travel-friendly detachable braided cloth USB cable has cable management for quick and easy stowage.
Cherry MX Red mechanical key switches
Smooth, linear key response for ultra fast double and triple taps without the audible click.
Short-Body Design
It fits into more places, and it's easier to pack and go.
Full-Size Keyboard Comfort
Standard key spacing so your fingers can stretch out
Gunmetal grey anodized aluminum chassis
Professional-grade look and feel plus the rugged durability you need for hours of gaming.
Every keystroke translates into accurate gameplay--even when multiple keys are pressed.
Detachable, braided cloth USB cable with cable management
It's durable and easy to stow, plus the K65 has cable routing to keep the cable locked in.
About Corsair Gaming Keyboards
Corsair gaming keyboards are designed for competitive play. Crafted with high-quality components and materials, they offer great key feel and the responsiveness you need when victory is essential. They deliver incredible responsiveness, customizability and precision to elevate your game.
Cherry MX red mechanical key switches
Smooth, linear key response for ultra fast double and triple taps without the audible click. -
Short-Body design
It fits into more places, and it is easier to pack and go. -
Full-size keyboard comfort
Standard key spacing so your fingers can stretch out. -
Anodized aluminum chassis
Professional-grade look and feel plus the rugged durability you need for hours of gaming. -
Every keystroke translates into accurate gameplay - even when multiple keys are pressed. -
It is durable and easy to stow, plus the K65 has cable routing to keep the cable locked in. -
About Corsair gaming keyboards
- CORSAIR Vengeance K65 Compact Mechanical Gaming - keyboard - UK - gunmetal grey anodised aluminium
- Keyboard
- Interface
- USB
- Connectivity Technology
- Wired
- Localization and Layout
- UK
- Hot Keys Qty
- 10
- Hot Keys Function
- Volume, mute
- CHERRY MX Red technology, Windows Lock key, cable management
- Gunmetal grey anodised aluminium
- 35.6 cm x 16.6 cm x 3.7 cm
- 863 g
- 2-year warranty
- Keyboard
- Interface
- USB
Input Device
- Hot Keys Qty
- 10
- Hot Keys Function
- Volume, mute
- UK
- Keyboard Technology
- Mechanical
- Anti-ghosting
- 35.6 cm
- 16.6 cm
- 3.7 cm
- 863 g
- Cables Included
- 1 x USB cable
- OS Required
- Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Windows 8
- Limited warranty - 2 years
