The Corsair Raptor HS40 gaming headset offers 7.1 surround sound and a noise canceling microphone in a comfortable, closed back design that's great for extended gaming sessions. It features 40mm Neodymium audio drivers for better sound quality, and the padded earcups and headband give you the comfort you need to keep your head in the game.
7.1 Channel Surround Sound
Accurate reproduction of multichannel gaming audio for a tactical advantage. -
40mm Neodymium drivers for better audio quality
The large diameter drivers are equipped with high-sensitivity magnets for better sound with lower distortion. -
Circumaural, closed-back design
The earcups fit around the ears to help block distracting environmental noise, and the solid outer shell helps prevent bothering others when you're playing or listening. -
Noise canceling microphone
The microphone automatically screens out background noise, so you can be heard clearly. -
Padded earcups and headband
Extra comfort, so you can keep your head in the game longer without your gear getting in the way.
- CORSAIR Raptor HS40 7.1 USB Gaming - headset
- Product Type
- Headset - wired
- Localisation
- Europe
- Headphones Form Factor
- Full size binaural
- Connectivity Technology
- Wired
- Audio Specifications
- Frequency Response 20 - 20000 Hz
- Impedance
- 32 Ohm
- Controls
- Volume
- 2-year warranty
- Product Type
- Headset - wired
- Localisation
- Europe
Audio Output
- Headphones Cup Type
- Closed
- Wired
- 20 - 20000 Hz
- Impedance
- 32 Ohm
- Diaphragm
- 40 mm
- Magnet Material
- Neodymium
- In-Cord Volume Control
Microphone
- Sensitivity
- -42 dB
- Impedance
- 2.2 kOhm
- 100 - 10000 Hz
- Audio Input Details
- Uni-directional - 100 - 10000 Hz - Output Impedance 2.2 kOhm
Remote Control
- Controls
- Volume
- Connector Type
- USB (4 PIN USB Type A)
- Cable Details
- USB cable - 2.7 m
- Limited warranty - 2 years
