Based on the Sandforce controller, the Corsair Force Series Solid-State Drive offers stutter-free response, fast performance, cooler and quieter operations for your notebook, netbook, and desktop PC.
If speed is what you are looking for and what you expect from your performance or gaming system the Corsair Force Series SSD's are the perfect choice. Based on the Sandforce controller, the Corsair Force Series SSD's are the ultimate performance drive. Your system will start-up faster, applications and games will load quicker and you will see a huge improvement in overall system responsiveness. The Corsair Force Series SSD is the ultimate SSD for your demanding storage requirements.
Affordable, large-capacity SSD performance
Force LE solid-state drives incorporate TLC NAND technology to provide affordable, large-capacity performance that's faster than hard drives. If you've been waiting to replace your mechanical hard drive with high-speed SSD, now it's easier than ever to upgrade. -
Faster than hard drives
Boot and shut down your PC faster, start your applications in the blink of an eye, and find your files and documents and instantly. -
Large storage capacity
The Force Series LE SSD provides lots of storage to satisfy your everyday needs - work, play, create, and keep all your videos, music, documents, and more. -
Low power consumption with DevSlp support
Force Series LE solid-state drives use dramatically less power than traditional hard drives for better power efficiency for desktops and longer battery life for laptops. -
Enhanced error correction
Protecting your data is essential. Force Series LE has built-in SmartECC and SmartRefresh technologies for reliable data retention and error correction. -
Static and dynamic wear-leveling with garbage collection
Smart wear-leveling with fast and efficient data management improves drive lifespan, reliability, and performance.
- CORSAIR Force Series LE - SSD - 960 GB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 960 GB
- NAND Flash Memory Type
- Triple-level cell (TLC)
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Shock resistant, DEVSLP SATA low power mode, SmartRefresh, S.M.A.R.T.
- 69.85 mm x 100.1 mm x 7 mm
- 50 g
- 3-year warranty
- Capacity
- 960 GB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- 69.85 mm
- 100.1 mm
- 7 mm
- 50 g
Performance
- Drive Writes Per Day (DWPD)
- 0.87
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 560 MBps (read) / 530 MBps (write)
- Maximum 4KB Random Write
- 85000 IOPS
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 2.5"
- OS Required
- Linux, Apple MacOS X, Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista
- Included Accessories
- 7mm to 9.5mm holder
- FCC
- Limited warranty - 3 years
- 0 °C
- 70 °C
- 0 - 90%
