Flash Voyager Vega is ultra-compact, fast, and a perfect complement for the latest ultra-slim PCs, car audio systems, or anywhere you want a lot of storage in a discreet design. The scratch-resistant hard chrome plated zinc alloy housing features an integrated loop for securely attaching to your key ring. Compatibility is no problem - you get USB 3.0 speed on the latest systems and full USB 2.0 support on mainstream PCs.
Ultra-compact design
Flash Voyager Vega is so small that you can leave it in your notebook's USB port and take it everywhere you go. -
It's not just for PCs
The small size also makes it perfect for the latest car audio systems, or any device which has a standard USB port. You can take your music collection with you everywhere, without the bulk of a traditional USB flash drive. -
USB 3.0 speed with universal USB 2.0 compatibility
You'll get super-fast file access on the latest PCs, and full support on mainstream systems. And, of course, it works with Windows, OS X and Linux with no driver installation necessary. -
Scratch resistant
Scratch resistant, hard chrome plated zinc alloy housing with blue activity LED. The sophisticated look goes great with the latest ultra-slim systems. -
One-piece design with an integrated key loop
Your Flash Voyager Vega securely attaches to your key ring when you're on the go.
- CORSAIR Flash Voyager Vega - USB flash drive - 32 GB
- Product Type
- USB flash drive
- Interface Type
- USB 3.0
- Storage Capacity
- 32 GB
- OS Required
- Linux, Apple MacOS X 10.6 or later, Microsoft Windows Vista SP1, Microsoft Windows 7 SP1, Windows 8, Windows 8.1
- 5-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 32 GB
- Interface Type
- USB 3.0
- Scratch-proof, metal body, key ring loop
- OS Required
- Limited warranty - 5 years
- 24 mm
- 12.2 mm
- 4.6 mm
- 30 g
