Flash Voyager Vega is ultra-compact, fast, and a perfect complement for the latest ultra-slim PCs, car audio systems, or anywhere you want a lot of storage in a discreet design. The scratch-resistant hard chrome plated zinc alloy housing features an integrated loop for securely attaching to your key ring. Compatibility is no problem - you get USB 3.0 speed on the latest systems and full USB 2.0 support on mainstream PCs.
- Corsair Flash Voyager Vega - USB flash drive - 32 GB
- Product Type
- USB flash drive
- Interface Type
- USB 3.0
- Storage Capacity
- 32 GB
- OS Required
- Linux, Apple MacOS X 10.6 or later, Microsoft Windows Vista SP1, Microsoft Windows 7 SP1, Windows 8, Windows 8.1
- 5 years warranty
- Product Type
- USB flash drive
- Storage Capacity
- 32 GB
- Compatibility
- Non-specific
- Interface Type
- USB 3.0
- Scratch-proof, metal body, key ring loop
- OS Required
- Limited warranty - 5 years
- 24 mm
- 12.2 mm
- 4.6 mm
- 30 g
