Flash Voyager Slider X2 is a compact USB 3.0 drive that doesn’t sacrifice size for performance. It has a smart design, with a USB connector that retracts for protection when you’re not using it. An activity LED tells you at a glance if it’s transferring data. It supports USB transfer speeds of up to 200 MB/s read and 90 MB/s write. The Slider X2 is backward compatible with USB 2.0, so you can use it with virtually any desktop or notebook.
- CORSAIR Flash Voyager Slider X2 - USB flash drive - 256 GB
- Product Type
- USB flash drive
- Interface Type
- USB 3.0
- Storage Capacity
- 256 GB
- OS Required
- Linux, Apple MacOS X, Microsoft Windows
- 5-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 256 GB
- Read Rate
- Up to 200 MB/s
- Write Rate
- Up to 90 MB/s
- Interface Type
- USB 3.0
- Retractable connector, LED access indicator
- Plug and Play
- OS Required
- Limited warranty - 5 years
- 9 g
