Corsair Flash Voyager Slider X1 USB 3.0 64GB
Quicklinx: B33FWS00 Mfr#: CMFSL3X1-64GB
Flash Voyager Slider X1 has a smart design with a USB connector that retracts for protection when you’re not using it. An activity LED tells you at a glance if it’s transferring data. It supports high-speed USB 3.0 transfers along with full USB 2.0 compatibility, so you can use it with virtually any desktop or notebook.
CORSAIR Flash Voyager Slider X1 - USB flash drive - 64 GB
USB flash drive
Interface Type
USB 3.0
Storage Capacity
64 GB
Linux, Apple MacOS X, Microsoft Windows
5-year warranty
USB flash drive
Storage Capacity
64 GB
Read Rate
Up to 130 MB/s
Interface Type
USB 3.0
LED access indicator
Plug and Play
Limited warranty - 5 years
9 g
