Flash Voyager Slider X1 has a smart design with a USB connector that retracts for protection when you're not using it. A blue activity LED tells you at a glance if it's transferring data. It's also universally compatible with Windows, Mac OS X and even Linux, with no driver necessary. It supports high-speed USB 3.0 transfers along with full USB 2.0 compatibility, so you can use it with virtually any desktop or notebook.
- CORSAIR Flash Voyager Slider X1 - USB flash drive - 256 GB
- Product Type
- USB flash drive
- Interface Type
- USB 3.0
- Storage Capacity
- 256 GB
- OS Required
- Linux, Apple MacOS X, Microsoft Windows
- 5-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 256 GB
- Read Rate
- Up to 130 MB/s
- Interface Type
- USB 3.0
- LED access indicator
- Plug and Play
- OS Required
- Limited warranty - 5 years
- 54 mm
- 23.3 mm
- 11 mm
- 9 g
