The Flash Voyager GTX USB 3.0 flash drive uses an SSD controller for performance that rivals solid-state drives. Files transfer at twice the speed of other high-performance USB drives, so you can manage enormous files and spend less quality time with the progress bar. It looks great, too, with sleek zinc alloy housing with aluminum accents.
- CORSAIR Flash Voyager GTX - USB flash drive - 128 GB
- Product Type
- USB flash drive
- Interface Type
- USB 3.0
- Storage Capacity
- 128 GB
- OS Required
- Linux, Microsoft Windows, Apple MacOS X or later
- 5-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 128 GB
- Read Rate
- Up to 450 MB/s
- Write Rate
- Up to 360 MB/s
- Interface Type
- USB 3.0
- Integrated SSD controller
- OS Required
- Limited warranty - 5 years
- 78.12 mm
- 26.4 mm
- 10.8 mm
- 52 g
