Product
Corsair DDR4 2133MHz 8GB Module 1.2V Standard SO-DIMM
Quicklinx: C5JCWS00 Mfr#: CMSO8GX4M1A2133C15
This Corsair ValueSelect DDR4 SODIMM memory module is designed to guarantee maximum compatibility. It is assembled from select components and carefully screened for stable, reliable operation.
CORSAIR Value Select - DDR4 - 8 GB - SO-DIMM 260-pin - unbuffered
RAM memory
8 GB
Memory Type
DDR4 SDRAM - SO-DIMM 260-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2133 MHz (PC4-17000)
Latency Timings
CL15 (15-15-15-36)
Unbuffered
Voltage
1.2 V
8 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
SO-DIMM 260-pin
Speed
Latency Timings
CL15 (15-15-15-36)
Non-ECC
Unbuffered
Voltage
1.2 V
RAM Performance
SPD - 2133 MHz - 1.2 V - CL15 - 15-15-15-36 , Tested - 2133 MHz - 1.2 V - CL15 - 15-15-15-36
