Corsair Crystal Series 570X RGB ATX Mid Tower Case - Red
Quicklinx: D8YBWS00 Mfr#: CC-9011111-WW
With immaculate tempered glass enclosing the entire chassis, every component of your build is on display for all to see, including three vivid RGB LED fans and a built-in LED controller. Room for a few case fans, and fully compatible with radiators. Removable fan trays in the front and top of the chassis allow for additional space or mounting cooling outside of the chassis.
  • Four-panel tempered glass on every side of the case
    The extremely beautiful case Corsair has made. With tempered glass enclosing the entire chassis, every component of your build is on display for all to see.
  • Direct airflow path to keep your CPU and GPU running cooler
    Light up your build with brilliant LED effects. Three RGB LED fans and LED controller keeps your components running cool.
  • Room for practically anything
    Create as much space as you want with room for a few case fans, virtually every-size radiator or by removing fan trays.
  • Cable management made simple
    Cable routing channels with velcro cable straps for clean cable management.
CORSAIR Crystal Series 570X RGB - mid tower - ATX
System cabinet
Mid tower
Red
I/O Connectors
2 x USB 3.0 , 1 x headphones , 1 x microphone
Supported Motherboards
ATX, microATX, Mini-ITX
System Cabinet Features
Top panel dust filter, front dust filter, rear dust filter, supports 120 mm radiator in rear, supports 120/240 mm radiator in top, RGB illumination, supports 120/240/280/360 mm radiator in front panel
No power supply
Specification Compliance
ATX
23.4 cm x 48 cm x 51.2 cm
10.9 kg
Mid tower
Max Mainboard Size
ATX
ATX
Internal Bays Qty
4
Product Material
Steel, tempered glass
Red
Cooling System
Front: 120 mm fan x 3 / 2 x 140 mm fan supported , Top: 120/140 mm fan mount x 2 , Rear: 120 mm fan mount x 1
CPU Cooler Max Height
170 mm
Video Card Max Length
370 mm
Power Supply Max Length
225 mm
Expansion Bays
2 (total) / 2 (free) x internal - 3.5" , 2 (total) / 2 (free) x internal - 2.5"
Expansion Slots
7
2 x USB 3.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack
No power supply
23.4 cm
48 cm
51.2 cm
10.9 kg
