Corsair Cooling H115i Pro RGB 280mm Liquid
Quicklinx: DQX2WS00 Mfr#: CW-9060032-WW
£120.92 ex VAT
£145.10 inc VAT
The CORSAIR Hydro Series H115i PRO is an all-in-one RGB liquid CPU cooler with a 280mm radiator built for low-noise cooling performance and bold styling with an RGB LED pump head. Two included 140mm ML Series magnetic levitation PWM fans provide great airflow while producing no more than 20 dBA of noise, pushing the performance of your build while staying whisper quiet. Take control with CORSAIR LINK software and customize lighting, monitor temperatures and precisely adjust fan speeds, or stop the cooling fans entirely with the H115i's Zero RPM fan mode. Easy to install and compatible with most modern CPU sockets, the H115i makes it easy to cool your system in silence and style.
CORSAIR Hydro Series H115i PRO Liquid CPU Cooler processor liquid cooling system
Processor liquid cooling system
Compatibility
LGA1156 Socket, Socket AM2, LGA1366 Socket, Socket AM3, LGA1155 Socket, LGA2011 Socket, Socket FM1, Socket FM2, LGA1150 Socket, LGA2011-3 Socket, LGA1151 Socket, Socket AM4, LGA2066 Socket
Heatsink Material
Aluminium with copper base
Fans Qty
Dual
Fan Diameter
140 mm
Fan Bearing
Magnetic bearing
Rotation Speed
1200 rpm
Air Flow
55.4 cfm
Noise Level
20.4 dBA
Pulse-width modulation (PWM) support, RGB LED
31.5 cm x 2.9 cm x 14.3 cm
958 g
Corsair Link
5-year warranty
31.5 cm
2.9 cm
14.3 cm
958 g
19.2 cm x 36.1 cm x 16.9 cm / 2.24 kg
Heatsink & Fan
Compatible With
Heatsink Material
Fans Qty
2
Fan Diameter
140 mm
Fan Bearing
Magnetic bearing
Rotation Speed
1200 rpm
Air Flow
55.4 cfm
Air Pressure
1.27 mm
Noise Level
20.4 dBA
Mounting Kit
Included
Corsair Link
Limited warranty - 5 years
Brand: Corsair
Price Range Ex VAT: 100 - 150
