Your basket is empty
Corsair Carbide Series SPEC-03 WHITE LED Mid Tower Gaming Case
Quicklinx: 9JBYWS00 Mfr#: CC-9011053-WW
Carbide Series SPEC-03 has an extremely aggressive, game-oriented design and superior air cooling for your high-performance GPUs. The cleverly designed interior allows for the included LED-lit front intake fan to draw cold air directly to your graphics cards, and there's room for up to six fans for massive cooling potential.
There's a huge windowed side panel that lets you admire your work, and the cable routing system and dust filters help you build a clean system and keep it clean, too. Tool-free installation of up to three 3.5" hard drives and two solid-state drives make it easy to add and upgrade storage. And, it's easy to live with, too - the dual front panel USB 3.0 ports let you take advantage of the high-speed storage devices.
  • Tons of fan mounts: Front - 2 x 140/120mm (2 x 120mm LED included), Top - 2 x 120mm, Rear - 120mm (included), Bottom - 120mm
  • 2 x USB 3.0 front ports with internal connector
  • Large side panel window
  • Cable routing and CPU cooler backplate motherboard cutouts
  • Seven PCIe slots with room for long graphics cards up to 426mm long
  • Install up to three 3.5" and two 2.5" drives simultaneously - tool free.
  • Dust filters for front and PSU intake.
Box Contents
  • Carbide Series SPEC-03 Mid Tower Gaming Case
  • Accessories box with screws, zip ties, and other mounting hardware.
  • Warranty and Support Information
Corsair Carbide Series SPEC-03 - mid tower - ATX
System cabinet
Mid tower
I/O Connectors
2 x USB 3.0 , 1 x headphones , 1 x microphone
Supported Motherboards
ATX, microATX, Mini-ITX
System Cabinet Features
Windowed side panel, screwless drive bays, front dust filter, CPU cut-out, cable management holes, supports 120 mm radiator in rear, PSU dust filters
No power supply
Specification Compliance
ATX
21.5 cm x 49.3 cm x 42.6 cm
5.65 kg
2 years warranty
Mid tower
Max Mainboard Size
ATX
ATX
Internal Bays Qty
5
Front Accessible Bays Qty
2
Cooling System
Front: 120 mm fan x 1 / intake / white LED , Front: 120/140 mm fan mount x 2 , Top: 120 mm fan mount x 2 , Rear: 120 mm fan x 1 , Bottom: 120 mm fan mount x 1
CPU Cooler Max Height
157 mm
Video Card Max Length
420 mm
Power Supply Max Length
288 mm
Expansion Bays
2 (total) / 2 (free) x front accessible - 5.25" , 3 (total) / 3 (free) x internal - 3.5" , 2 (total) / 2 (free) x internal - 2.5"
Expansion Slots
7
2 x USB 3.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack
No power supply
21.5 cm
49.3 cm
42.6 cm
5.65 kg
