Corsair Carbide Series SPEC-03 BLUE LED Mid Tower Gaming Case
Quicklinx: 9RT2WS00 Mfr#: CC-9011058-WW
The SPEC-03 features an industrial, high-airflow front panel, a huge windowed side panel and a front 120mm LED fan. Add to that our USB 3.0 and native, tool-free SSD and HDD installation and you can have your killer gaming rig up and running in minutes.
Most cases at this price point don't give you the combination of great looks and great features that the SPEC-03 does. Up to dual 140mm front intake fan, an rear 120mm exhaust, and room for massive graphics cards makes the SPEC-03 stand out among the crowd.
  • Front - 2 x 140/120mm (1 x 120mm LED included)
  • Top - 2 x 120mm
  • Rear - 120mm (included)
  • Bottom - 120mm
  • 2 x USB 3.0 front ports with internal connector
  • Large side panel window
  • Cable routing and CPU cooler backplate motherboard cutouts
  • Seven PCIe slots with room for long graphics cards up to 426mm long
  • Install up to three 3.5" and two 2.5" drives simultaneously - tool free.
  • Dust filters for front and PSU intake
  • Huge side panel window
    The aggressive look of the SPEC-03 makes it look great on the outside, but there's beauty on the inside of a well-built system, too. The large side panel window lets you show it off.
  • LED front intake fan, with room for more
    The 120 mm front intake fan is bathed in soft LED lighting, and it's oriented to draw cool air directly across your graphics cards. And if you want even more ventilation, you can add a second 120 mm fan or even dual 140 mm fans.
  • Flexible cooling potential
    Like all Corsair cases, the SPEC-03 is designed for cooling, so you're covered if you're overclocking, running multiple GPUs, or if you just want more airflow. There are mounting points for up to six fans, including dual front 140 mm or 120 mm fans, dual 120 mm fans on top, a bottom-mounted 120 mm fan, and a rear 120 mm fan.
  • Multiple drive bays
    In addition to the two standard 5.25" optical drive bays, there are three 3.5" hard drive bays and two 2.5" solid-state drive bays.
  • Easy system builds, maintenance and upgrades
    Builds should be easy, no matter what your budget. Drive installation is tool-free, and you get cable routing holes for neater-looking builds and better airflow. And, there's a CPU cutout to allow for cooling upgrades without removing the motherboard.
CORSAIR Carbide Series SPEC-03 - tower - ATX
System cabinet
Tower
Windowed Side Panel
I/O Connectors
2 x USB 3.0 , 1 x headphones , 1 x microphone
Supported Motherboards
ATX, microATX, Mini-ITX
System Cabinet Features
Screwless drive bays, front dust filter, CPU cut-out, cable management holes, supports 120 mm radiator in rear, PSU dust filters
No power supply (ATX)
21.5 cm x 49.3 cm x 42.6 cm
5 kg
Tower
Windowed Side Panel
Max Mainboard Size
ATX
Internal Bays Qty
5
Front Accessible Bays Qty
2
Product Material
Steel
Cooling System
Front: 120 mm fan x 1 / intake / blue LED , Front: 120/140 mm fan mount x 2 , Top: 120 mm fan mount x 2 , Rear: 120 mm fan x 1 , Bottom: 120 mm fan mount x 1
CPU Cooler Max Height
157 mm
Video Card Max Length
420 mm
Power Supply Max Length
288 mm
Expansion Bays
2 (total) / 2 (free) x front accessible - 5.25" , 3 (total) / 3 (free) x internal - 3.5" , 2 (total) / 2 (free) x internal - 2.5"
Expansion Slots
7
2 x USB 3.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack
No power supply
Specification Compliance
ATX
21.5 cm
49.3 cm
42.6 cm
5 kg
