Your basket is empty
Corsair Carbide Series SPEC-01 BLUE LED Mid Tower Gaming Case
Quicklinx: 9JBZWS00 Mfr#: CC-9011056-WW
Carbide Series SPEC-01 is proof that great looks, smart design, and durable construction don't need to be pricy, and that basic doesn't need to be boring. You get aggressive styling, a huge side panel window for admiring your components, and an LED-lit front intake fan that draws cool air directly to your graphics cards.
Inside, there's room for up to five fans, and the four combination hard drive / SSD trays make storage installation and upgrades quick and easy. Cable routing cutouts help you reduce clutter, and the built-in dust filters help protect your components. Up front, the USB 3.0 connector gets you up to speed with the latest high-performance storage devices.
  • Tons of fan mounts: Front - 2 x 140/120mm (1 x 120mm LED included), Top - 2 x 120mm, Rear - 120mm
  • USB 3.0 front port with internal connector
  • Large side panel window
  • Cable routing and CPU cooler backplate motherboard cutouts
  • Seven PCIe slots with room for long graphics cards up to 420mm long
  • Install up to four storage drives, your choice of 3.5" or 2.5", each tray fits both.
  • Dust filters for front and PSU intake.
Box Contents
  • Carbide Series SPEC-01 Mid Tower Gaming Case
  • Accessories box with screws, zip ties, and other mounting hardware.
  • Warranty and Support Information
CORSAIR Carbide Series SPEC-01 - mid tower - ATX
System cabinet
Mid tower
I/O Connectors
1 x USB 3.0 , 1 x headphones , 1 x microphone , 1 x USB 2.0
Supported Motherboards
ATX, microATX, Mini-ITX
System Cabinet Features
Windowed side panel, screwless drive bays, front dust filter, CPU cut-out, cable management holes, supports 120 mm radiator in rear, PSU dust filters, made of steel
No power supply
Specification Compliance
ATX
20 cm x 44.7 cm x 42.8 cm
4.8 kg
2 years warranty
Mid tower
Max Mainboard Size
ATX
ATX
Internal Bays Qty
4
Front Accessible Bays Qty
2
Cooling System
Front: 120 mm fan x 1 / intake / blue LED , Front: 120/140 mm fan mount x 2 , Top: 120 mm fan mount x 2 , Rear: 120 mm fan mount x 1
CPU Cooler Max Height
150 mm
Video Card Max Length
414 mm
Expansion Bays
2 (total) / 2 (free) x front accessible - 5.25" , 4 (total) / 4 (free) x internal - 2.5" / 3.5" shared
Expansion Slots
7
1 x USB 3.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack , 1 x USB 2.0
No power supply
20 cm
44.7 cm
42.8 cm
4.8 kg
