Corsair Carbide Series Air 740 High Airflow ATX Cube Case
Quicklinx: CF1HWS00 Mfr#: CC-9011096-WW
BIGGER IS BETTER
CORSAIR Carbide Series PC cases have the high-end features you need, and nothing you don’t. Designed to be the foundation of awesome, yet approachable PCs, they combine the latest case technologies and ergonomic innovations with amazing cooling potential, and plenty of room to build and expand.
Room to Breathe
The unique design of Carbide Series Air 740 utilizes dual chambers to deliver cooler air to your CPU, graphics cards, motherboard, and memory without your drives or power supply getting in the way.
Cool it your way
The included Air Series AF140L intake and exhaust fans deliver superior ventilation with less noise. The Air 740 features expansion room for advanced air cooling and water cooling setups.
Industrial-style ergonomics and space-optimized internal design
Offers massive internal volume by moving the power supply, SSD and optical drives into a separate chamber.
Expansion room
For up to six 120mm or five 140mm fans, a 240mm or 280mm top radiator, and a 240mm, 280mm, or 360mm radiator on the front panel.
  • Room to breathe
    The special design of Carbide Series Air 740 utilizes dual chambers to deliver cooler air to your CPU, graphics cards, motherboard, and memory without your drives or power supply getting in the way.
  • Cool it your way
  • Industrial-style ergonomics and space-optimized internal design
    This case offers massive internal volume by moving the power supply, SSD and optical drives into a separate chamber.
CORSAIR Carbide Series Air 740 - tower - ATX
System cabinet
Tower
Windowed Side Panel
I/O Connectors
2 x USB 3.0 , 1 x headphones , 1 x microphone
Supported Motherboards
ATX, microATX, Mini-ITX
System Cabinet Features
Screwless drive bays, cable management holes, supports 120/140/240/280/360 mm radiator in front panel, supports 120/140 mm radiator in rear, supports 120/140/240/280 mm radiator in top, supports 120/140/240/280 mm radiator in bottom
No power supply (ATX)
42.6 cm x 34 cm x 51 cm
8.82 kg
Tower
Windowed Side Panel
Max Mainboard Size
ATX
Internal Bays Qty
7
Product Material
Steel
Cooling System
Front: 140 mm fan x 2 / intake / 2 x 140 mm fan or 3 x 120 mm fan supported , Top: 120/140 mm fan mount x 2 / exhaust , Bottom: 120/140 mm fan mount x 2 , Rear: 140 mm fan x 1 / 1 x 120/140 mm fan supported
CPU Cooler Max Height
170 mm
Video Card Max Length
330 mm
Power Supply Max Length
225 mm
Expansion Bays
4 (total) / 4 (free) x internal - 2.5" , 3 (total) / 3 (free) x internal - 3.5"
Expansion Slots
8
2 x USB 3.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack
No power supply
Specification Compliance
ATX
42.6 cm
34 cm
51 cm
8.82 kg
