Product
Corsair Carbide Series Air 540 High Airflow ATX Cube Case
Quicklinx: 8RGYWS00 Mfr#: CC-9011030-WW
The unconventional design of Carbide Series Air 540 utilizes dual chambers to deliver cooler air to your CPU, graphics cards, motherboard, and memory without your drives or power supply getting in the way. The included custom Air Series AF140L intake and exhaust fans provide great airflow performance at lower noise levels than typical case fans. And, you can mount up to six 120mm or five 140mm fans, with 280mm top radiator support and room for a 360mm radiator on the front panel. Like all Corsair cases, Carbide Series Air 540 is designed for fast, neat, and satisfying builds. The tinted, oversized flush-mount side window lets you show off your work.
  • Dual-chamber Direct Airflow Path™ design for outstanding cooling potential
  • Clever, space-saving design still offers lots of internal volume
  • Includes three High Performance Air Series AF140L fans for better, quieter cooling
  • Tons of expansion room for high performance air cooling and liquid cooling
  • Full side panel window
  • Front dust filter
  • Black interior
  • Cable routing cutouts with rubber grommets
  • CPU cutout in motherboard tray for easy CPU cooler swap-out
  • Dual front USB 3.0 ports with internal connector
  • Headphone, Microphone front ports
  • Eight expansion slots for quad GPU installations
  • Fan Mount Locations
  • Front: 2 x 140mm (included), 3 x 120mm (pre-spaced for radiators)
  • Top: 2 x 140mm or 2 x 120mm (pre-spaced for radiators)
  • Rear: 1 x 140mm (included) or 1 x 120mm
  • Dual 3.5" hot swap bays
  • Four 2.5" tool-free SSD drive cages
  • Maximum GPU Length 320mm
  • Maximum CPU Cooler Height 170mm
  • Maximum PSU length 200mm
  • Dimensions 415mm x 332mm x 458mm
  • Material Steel and plastic
  • Color Black
  • Model CC-9011030-WW
  • Drive Bays (x2) 5.25" tool-free (x2) 3.5"/2.5" tool-free Drive Caddies (Hot Swap) (x4) 2.5" tool-free SSD cage
  • Cooling (x2) AF140L 140mm Intake fans (x1) AF140L 140mm Exhaust fan
  • Expansion Slots 8
  • Motherboard E-ATX, ATX, Micro ATX, Mini ITX
  • Front I/O (x2) USB 3.0 (x1) Headphone, (x1) Mic
  • Power Supply ATX (not included)
  • Outstanding cooling
    The Direct Airflow Path design utilizes dual chambers to deliver cooler air to your CPU, graphics cards, motherboard, memory, and other PCI-E components without your drives or power supply getting in the way.
  • Ideal for advanced air cooling and water cooling
    You can mount up to six 120 mm or five 140 mm fans, or install a 240 mm or 280 mm top radiator and a 240 mm, 280 mm, or even 360 mm radiator on the front panel. Corsair's innovative cable routing system gives you more options for hiding pumps and tubing out of the way.
  • Built for builders
    Like all Corsair cases, Carbide Series Air 540 is designed for fast, neat, and satisfying builds. You get tool-free PCI-E and storage installation, two internal hot-swap drive bays, and more features for making assembly, upgrades, and maintenance quick and easy. And, the tinted, oversized flush-mount side window lets you show off your work.
CORSAIR Carbide Series Air 540 - mid tower - extended ATX
System cabinet
Mid tower
I/O Connectors
2 x USB 3.0 , 1 x headphones , 1 x microphone
Supported Motherboards
ATX, microATX, Mini-ITX, Extended ATX
System Cabinet Features
Windowed side panel, screwless drive bays, front dust filter, Direct Airflow Path design
No power supply
Specification Compliance
ATX
41.5 cm x 33.2 cm x 45.8 cm
7.4 kg
2 years warranty
Mid tower
Max Mainboard Size
Extended ATX
ATX
Internal Bays Qty
4
Front Accessible Bays Qty
2
Hot-Swap Bays Qty
2
Product Material
Steel, acrylic
Cooling System
Front: 140 mm fan x 2 / intake , Rear: 140 mm fan x 1 / exhaust
CPU Cooler Max Height
170 mm
Video Card Max Length
320 mm
Power Supply Max Length
250 mm
Expansion Bays
4 (total) / 4 (free) x internal - 2.5" , 2 (total) / 2 (free) x hot-swap - 2.5" / 3.5" shared , 2 (total) / 2 (free) x front accessible - 5.25"
Expansion Slots
8
2 x USB 3.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack
No power supply
41.5 cm
33.2 cm
45.8 cm
7.4 kg
