The Carbide Series™ 300R windowed is a compact expression of the Corsair philosophy: great systems begin with a great case. Open the easy-access side panel to find a builder-friendly design with three tool-free optical drive bays and four tool-free hard drive bays with integrated 2.5" SSD compatibility. There's room for extra-long graphics cards, and the matte black interior really shows off your gear. Finish off your build with a cable routing system that keeps wires and cables out of sight and out of the airflow path for a clean, uncluttered look.
The 300R keeps your hardware cool with amazing airflow, including a 140mm front intake fan and a 120mm rear exhaust fan. There's room to add five additional fans, including dual side-panel fan locations that can deliver cool air directly to your graphics cards. And, the dust filters are removable for easy maintenance. Features like these make the Corsair Carbide Series 300R the foundation of your next great system.
- Oversized, tinted window with room for dual 120mm or 140mm fans
- Room for graphics cards up to 450mm long.
- USB 3.0 front panel connectors.
- Built-in compatibility for SSDs in the four hard drive bays gives you the flexibility you need.
- Keep your system cool with up to 7 fan mount locations.
- Easily accessible dust filters keep the cool air flowing over your valuable components.
- Install or upgrade your CPU heatsink quickly with the easy-access backplate cutout.
- Optimize airflow and keep your system neat and tidy using the intelligent cable management system.
A compact expression of Corsair's gaming philosophy
Great systems start with a great case, and Carbide Series 300R provides a remarkable number of features in a compact chassis. Easy access, lots of room for expansion, and superior cooling make the 300R a great choice for building powerful PCs that don't take up a lot of room. -
Serious cooling potential
The 300R is equipped with two fans for intake and exhaust, and the integrated dust filters on the front and bottom intakes are easy removable. There's room for you to install five more fans, including mounting points for two side panel 120mm fans for drawing cool air directly over your GPUs. If you're building a multi-GPU gaming rig, proper graphics ventilation is essential. -
It's big where it counts
Despite its size, the 300R can fit extra-long graphics cards of up to 450mm length, and it has three optical drive bays and four hard drive bays. All the bays are tool-free, and the hard drive bays have integrated support for 2.5" drives, so you won't need to deal with adapters when installing SSDs. -
Build quality
Whether you're building multiple systems or just one, and whether you're a professional or if it's your very first build, the 300R has the smart features that matter. Just like the drive bays, the side panels are tool-free, so you'll spend less quality time with your screwdriver. The interior has a CPU cutout for quick installing or upgrading of CPU heatsinks, and Corsair's innovative cable management system provides a straightforward way to route cables behind the motherboard, not across it where it can interfere with airflow and give your system a cluttered look.
- CORSAIR Carbide Series 300R Windowed - tower - ATX
- Product Type
- System cabinet
- Form Factor
- Tower
- Windowed Side Panel
- Black
- I/O Connectors
- 2 x USB 3.0 , 1 x headphones , 1 x microphone
- Supported Motherboards
- ATX, microATX, Mini-ITX
- System Cabinet Features
- Screwless drive bays, front dust filter, bottom dust filter
- Power Device
- No power supply (ATX)
- 21 cm x 48.5 cm x 44.9 cm
- 7.21 kg
- 2-year warranty
- Form Factor
- Tower
- Max Mainboard Size
- ATX
- Internal Bays Qty
- 4
- Front Accessible Bays Qty
- 3
- Product Material
- Steel
- Black
- Cooling System
- Side: 120/140 mm fan mount x 2 , Top: 120/140 mm fan mount x 2 , Front: 120/140 mm fan mount x 2 , Front: 140 mm fan x 1 , Rear: 120 mm fan x 1 , 120 mm fan mount x 1
- CPU Cooler Max Height
- 170 mm
- Video Card Max Length
- 450 mm
- Power Supply Max Length
- 240 mm
- Expansion Bays
- 3 (total) / 3 (free) x front accessible - 5.25" , 4 (total) / 4 (free) x internal - 2.5" / 3.5" shared
- Expansion Slots
- 7 x Expansion Slot
- 2 x USB 3.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack
- Power Device
- No power supply
- Specification Compliance
- ATX
- 21 cm
- 48.5 cm
- 44.9 cm
- 7.21 kg
- Limited warranty - 2 years
