Corsair Carbide Series 275R Tempered Glass ATX Case - White
Quicklinx: DF20WS00 Mfr#: CC-9011133-WW
Case Form Factor: Mid tower
Motherboard Form Factor: ATX
Colour: White, White
More than 50 in stock
£61.32 ex VAT
£73.58 inc VAT
Marketing description is not available.
  • Minimalist design, maximum features
    The CORSAIR Carbide Series 275R is a compact mid-tower ATX case that matches minimalist design and edge-to-edge window with a straightforward interior layout.
  • Full window side panel
    Edge-to-Edge full window side panel shows off your system in style.
  • Clean and minimalist design
    Clean lines, curved edges with soft accent lighting.
  • Expansive storage space
    Rugged-construction steel drive trays provide ample room for additional SSDs and hard drives.
  • Built-in cable routing
    Dedicated cable routing compartment enables effortlessly clean builds.
  • Direct Airflow Path cooling
    Two included CORSAIR SP120 fans ensure cool air is directed to the hottest components, without any interference from drive cages.
CORSAIR Carbide Series 275R - mid tower - ATX
System cabinet
Mid tower
White
I/O Connectors
2 x USB 3.0 , 1 x headphones , 1 x microphone
Supported Motherboards
ATX, microATX, Mini-ITX
System Cabinet Features
Windowed side panel, front dust filter, cable management holes, meshed top, supports 240 mm radiator in top, tempered glass side panel, PSU dust filters, supports 280/360 mm radiator in front panel
No power supply
Specification Compliance
ATX
21.1 cm x 45.5 cm x 46 cm
10.14 kg
Mid tower
Max Mainboard Size
ATX
ATX
Internal Bays Qty
5
Product Material
Glass, steel
White
Cooling System
Front: 120 mm fan x 1 / 3 x 120 mm or 2 x 140 mm fan supported , Rear: 120 mm fan x 1 , Top: 120 mm fan mount x 2
CPU Cooler Max Height
170 mm
Video Card Max Length
370 mm
Power Supply Max Length
180 mm
Expansion Bays
2 (total) / 2 (free) x internal - 3.5" , 3 (total) / 3 (free) x internal - 2.5"
Expansion Slots
7
2 x USB 3.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack
Accessory kit
No power supply
21.1 cm
45.5 cm
46 cm
10.14 kg
Colour: White
Colour: White
Brand: Corsair
Price Range Ex VAT: 50 - 100
