Corsair Carbide Series 100R Silent Edition Mid-Tower Case
Quicklinx: B60SWS00 Mfr#: CC-9011077-WW
Case Form Factor: Mid tower
Motherboard Form Factor: ATX
Colour: Black
More than 50 in stock
£44.67 ex VAT
£53.60 inc VAT
The Carbide Series 100R Mid Tower case has the versatility serious PC builders need with the clean, modern exterior design all users can agree with. Tool-free access to the interior, a flush-mounted window for admiring your components, and a range of cooling options are all available to the home builder at a spectacular value with this latest addition to the Corsair family.
  • Simple, elegant, and sharp
    It's the performance PC platform in stealth mode. With a mesh-free front panel, flush-mounted side panel window and clean lines, the 100R is both professional enough for the office and customizable enough for any home PC build.
  • Storage, simplified
    The simplicity begins with tool-free 3.5" and 5.25" drive installation, and all four hard drive trays provide solid-state drive support so you can mix and match to fit your needs. On the outside, dual USB 3.0 front panel ports give you quick and easy access to the latest high-speed portable hard drives and flash drives.
  • Creative cooling
    Five internal fan mounts let you customize your cooling to match your build. The case is designed to draw airflow directly to the GPU to help ensure that you and your graphics card will both keep your cool during intense gaming sessions.
  • The features that builders want
    Whether you're building one system or a dozen, you want the attention to detail that makes it easy. You'll appreciate things like cable routing channels for easy cable organization and better-looking builds, and the side panels are attached with thumbscrews so you can get in and out without hunting for a screwdriver.
CORSAIR Carbide Series 100R - Silent Edition - mid tower - ATX
System cabinet
Mid tower
I/O Connectors
2 x USB 3.0 , 1 x headphones , 1 x microphone
Supported Motherboards
ATX, microATX, Mini-ITX
System Cabinet Features
Screwless drive bays, fan speed controller, cable management holes, screwless side panels
No power supply
Specification Compliance
ATX
20 cm x 47.1 cm x 43 cm
4.8 kg
Mid tower
Max Mainboard Size
ATX
ATX
Internal Bays Qty
4
Front Accessible Bays Qty
2
Product Material
Steel
Cooling System
Front: 120 mm fan mount x 1 , Top: fan mount x 1 / 2 x 120 mm fan supported , Rear: 120 mm fan x 1 / exhaust , Front: fan mount x 1 / 1 x 120/140 mm fan supported
CPU Cooler Max Height
150 mm
Video Card Max Length
414 mm
Power Supply Max Length
260 mm
Expansion Bays
2 (total) / 2 (free) x front accessible - 5.25" , 4 (total) / 4 (free) x internal - 2.5" / 3.5" shared
Expansion Slots
7
2 x USB 3.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack
No power supply
20 cm
47.1 cm
43 cm
4.8 kg
Colour: Black
Brand: Corsair
Price Range Ex VAT: 0 - 50
