Corsair Carbide Clear 600C Inverse Windowed ATX Full Tower Case
Quicklinx: BYTXWS00 Mfr#: CC-9011079-WW
Quiet. Cool. Gorgeous. The 600C allows you to create a beautifully minimal modern PC layout, in full view through the giant transparent side panel. Conceal your cables with cleverly-positioned tie downs and routing grommets. Neatly house the PSU and drive bays behind removable covers. A massive panoramic window panel gives you a wide view of your high-powered components. The entire door panel opens with one effortless touch, for complete access to all your hardware.
  • Superb design
  • Cool means quiet
    600C's inverse ATX case design brings cool air directly to the components by eliminating obstruction from extra, unused drive bays. Direct airflow keeps fan noise to a minimum.
  • Inverse ATX layout
    With inverse ATX layout, airflow is easily directed at the hottest devices in your system; the GPU and CPU, and not wasted on drive cages.
  • Hinged and latched full side panel window
    Easily access your components with a single touch - and when closed, enjoy viewing every part of your build through the full side panel window.
  • Steel exterior
    Get rid of those plastic cases - the 600C has full steel front and top panels for extra durability and gorgeous good looks.
  • Three included fans
    Great airflow doesn't have to be noisy - the AF140L fans can push good amounts of air across your hottest devices without that annoying fan hum, and the three-speed fan controller lets you decide exactly how fast they run.
  • PSU and 5.25" bay cover
    Clean up the inside of your case by tucking all those cables and less-attractive drives behind a clean, refined PSU and 5.25" bay cover. Or remove them for assembly - it's up to you.
  • Easy to clean
    Easily access dust filters on front and bottom mean you'll never spend more than a minute getting dust out of your system.
  • Easy to build
    Tool-free drive installation, side panel access, and tons of cable routing possibilities and tie downs means you can spend less time building your PC and more time using it.
CORSAIR Carbide Series Clear 600C - tower - extended ATX
System cabinet
Tower
Windowed Side Panel
I/O Connectors
2 x USB 3.0 , 2 x USB 2.0 , 1 x headphones , 1 x microphone
Supported Motherboards
ATX, microATX, Mini-ITX, Extended ATX
System Cabinet Features
Fan speed controller, front dust filter, bottom dust filter
No power supply (ATX)
26 cm x 45.4 cm x 53.5 cm
10 kg
Tower
Windowed Side Panel
Max Mainboard Size
Extended ATX
Internal Bays Qty
5
Front Accessible Bays Qty
2
Cooling System
Front: 140 mm fan x 2 , Bottom: 120 mm fan mount x 3 / 3 x 120 mm or 2 x 140 mm fan supported , Rear: 140 mm fan x 1 , Front: 120/140 mm fan mount x 2
CPU Cooler Max Height
200 mm
Video Card Max Length
370 mm
Power Supply Max Length
210 mm
Expansion Bays
2 (total) / 2 (free) x front accessible - 5.25" , 2 (total) / 2 (free) x internal - 3.5" , 3 (total) / 3 (free) x internal - 2.5"
Expansion Slots
8
2 x USB 3.0 , 2 x USB 2.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack
No power supply
Specification Compliance
ATX
26 cm
45.4 cm
53.5 cm
10 kg
