Corsair Carbide 270R Mid-Tower ATX Solid Side-Panel Case
Quicklinx: CNDZWS00 Mfr#: CC-9011106-WW
Carbide series 270R is compact and engineered for building high-performance yet minimalist systems.
  • Look hot, run cold
    Take advantage of direct airflow cooling as well as ample room for radiators in the front, top and rear. Keep your rig running cool and quiet with 270R's enormous cooling potential.
  • Keep it clean
    Unobstructive exterior panels provide an understated look for an overall clean and minimalist design. The subtle cable routing compartment makes it even easier to achieve an effortlessly clean build.
CORSAIR Carbide Series 270R - tower - ATX
System cabinet
Tower
I/O Connectors
2 x USB 3.0 , 1 x headphones , 1 x microphone
Supported Motherboards
ATX, microATX, Mini-ITX
System Cabinet Features
Front dust filter, rugged, Direct Airflow Path design, supports 120 mm radiator in rear, PSU dust filters, supports 120/240 mm radiator in top, supports 120/240/280/360 mm radiator in front panel
No power supply (ATX)
21 cm x 50.9 cm x 46 cm
7.12 kg
Tower
Max Mainboard Size
ATX
Internal Bays Qty
4
Product Material
Steel
Cooling System
Rear: 120 mm fan x 1 , Front: 120/140 mm fan mount x 3 / 3 x 120 mm or 2 x 140 mm fan supported , Top: 120/140 mm fan mount x 2 , Rear: 120 mm fan mount x 1
CPU Cooler Max Height
170 mm
Video Card Max Length
370 mm
Power Supply Max Length
225 mm
Expansion Bays
2 (total) / 2 (free) x internal - 3.5" , 2 (total) / 2 (free) x internal - 2.5"
Expansion Slots
7
2 x USB 3.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack
Accessory kit
No power supply
Specification Compliance
ATX
21 cm
50.9 cm
46 cm
7.12 kg
