Corsair Air Series Sp120 Single Pack Green Led High Static Pressure
Quicklinx: 9LZ1WS00 Mfr#: CO-9050022-WW
Corsair Air Series LED high static pressure PC case fans combine efficient high pressure airflow with striking LED lighting. They're custom designed to deliver air directly to high-temperature components with less noise and turbulence than ordinary fans. The custom-molded blades are translucent and have a frosted texture, so the light from the four LEDs adds a dramatic effect.
Air Series SP fan models are designed for use in restricted spaces. They're ideal for radiator and heatsink use, as well as drive bay intakes and other locations where you're mounting a fan directly adjacent to a heat source. For general purpose case ventilation where you'd like high airflow with minimal excess noise, check out our AF120 and AF140 LED fans.
  • Tuned for high pressure air delivery directly to components
  • Better performance than standard case fans
  • LED-lit translucent, frosted fan blades for a dramatic effect
  • Specially designed fan blades and a sleeved bearing system for less vibration, noise and turbulence
  • High static pressure cooling with led illumination
  • Designed for restricted spaces
    Air Series fan models are designed for use in restricted spaces. They're ideal for radiator and heatsink use, as well as drive bay intakes and other locations where you're mounting a fan directly adjacent to a heat source.
CORSAIR Air Series LED SP120 High Static Pressure - case fan
Case fan
Package Content
Mounting screws for case fans
Green
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Sleeve bearing
Rotation Speed
1650 rpm
Air Flow
57.24 cfm
Noise Level
26.4 dBA
Power Connector
3-pin plug
Rated Voltage
12 V
Green LED x4, custom-molded fan blades
140 g
Case fan
Package Content
140 g
Green
Heatsink & Fan
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Sleeve bearing
Rotation Speed
1650 rpm
Air Flow
57.24 cfm
Air Pressure
1.46 mm
Noise Level
26.4 dBA
Power Connector
3-pin plug
Rated Voltage
12 V
Operation Voltage
7 - 12 V
Rated Current
0.26 A
Mounting Kit
Included
Limited warranty: - 2 years
