The wide body, low-pitch blades of the SP120 fans combined with the custom housing provides outstanding static pressure and airflow through heatsinks or radiators. With rubberized corners, a quiet and reliable advanced hydraulic bearing, and an included step-down resistor for even quieter operation, the SP120 truly is the strong, silent type.
- CORSAIR Air Series SP120 Quiet Edition - case fan
- Product Type
- Case fan
- Package Content
- Mounting screws for case fans, 3 replaceable colour rings
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Fan Bearing
- Hydraulic bearing
- Rotation Speed
- 1450 rpm
- Air Flow
- 37.85 cfm
- Noise Level
- 23 dBA
- Rubberised corners
- 200 g
- 2-year warranty
- Product Type
- Case fan
- Package Content
- 200 g
Heatsink & Fan
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Fan Bearing
- Hydraulic bearing
- Rotation Speed
- 1450 rpm
- Air Flow
- 37.85 cfm
- Air Pressure
- 1.29 mm
- Noise Level
- 23 dBA
- Rated Current
- 0.08 A
- Mounting Kit
- Included
- Limited warranty: - 2 years
