Product
Corsair Air Series SP120 Quiet Edition (Single Pack)
Quicklinx: 887HWS00 Mfr#: CO-9050005-WW
The wide body, low-pitch blades of the SP120 fans combined with the custom housing provides outstanding static pressure and airflow through heatsinks or radiators. With rubberized corners, a quiet and reliable advanced hydraulic bearing, and an included step-down resistor for even quieter operation, the SP120 truly is the strong, silent type.
CORSAIR Air Series SP120 Quiet Edition case fan
Case fan
Package Content
Mounting screws for case fans, 3 replaceable colour rings
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Hydraulic bearing
Rotation Speed
1450 rpm
Air Flow
37.85 cfm
Noise Level
23 dBA
Rubberised corners
200 g
Case fan
Package Content
200 g
Heatsink & Fan
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Hydraulic bearing
Rotation Speed
1450 rpm
Air Flow
37.85 cfm
Air Pressure
1.29 mm
Noise Level
23 dBA
Rated Current
0.08 A
Rubberised corners
Mounting Kit
Included
