Corsair Air Series SP120 High Performance Edition (Twin Pack)
Quicklinx: 85S2WS00 Mfr#: CO-9050008-WW
The advanced design of the SP120 provides the higher static pressure that radiators and heatsinks demand, while maintaining a quiet noise profile. Seven ultra-wide, custom-molded blades deliver high static pressure, and the customized fan enclosure helps airflow move in the right direction. The rubber mounts and the advanced hydraulic bearing system combine high reliability with low-noise operation.
Cooling today's high-performance PCs is a complex task, and a single fan design can't meet every need. The fan you use to exhaust hot air out of your case might not be the best fan to mount flush against a heatsink or radiator.
Static pressure is the measure of how well a fan can push air in this type of highly restrictive environment, and this is where the SP120 excels. It's an ideal solution for radiator and heatsink use, as well as drive bay intakes, and other locations where you're mounting a fan directly adjacent to a heat source.
CORSAIR Air Series SP120 High Performance Edition case fan
Case fan
Packaged Quantity
2 (specifications are for single item)
Package Content
Mounting screws for case fans, 3 replaceable colour rings, voltage reduction adapter
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Hydraulic bearing
Rotation Speed
2350 rpm
Air Flow
62.7 cfm
Noise Level
35 dBA
Rated Voltage
12 V
Rubberised corners
200 g
Packaged Quantity
Case fan
Package Content
200 g
Security Cable Lock
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Hydraulic bearing
Rotation Speed
2350 rpm
Air Flow
62.7 cfm
Air Pressure
3.1 mm
Noise Level
35 dBA
Rated Voltage
12 V
Rated Current
0.18 A
Rubberised corners
