The advanced design of the SP120 provides the higher static pressure that radiators and heatsinks demand, while maintaining a quiet noise profile. Seven ultra-wide, custom-molded blades deliver high static pressure, and the customized fan enclosure helps airflow move in the right direction. The rubber mounts and the advanced hydraulic bearing system combine high reliability with low-noise operation.
Cooling today's high-performance PCs is a complex task, and a single fan design can't meet every need. The fan you use to exhaust hot air out of your case might not be the best fan to mount flush against a heatsink or radiator.
Static pressure is the measure of how well a fan can push air in this type of highly restrictive environment, and this is where the SP120 excels. It's an ideal solution for radiator and heatsink use, as well as drive bay intakes, and other locations where you're mounting a fan directly adjacent to a heat source.
- CORSAIR Air Series SP120 High Performance Edition - case fan
- Product Type
- Case fan
- Package Content
- Mounting screws for case fans, 3 replaceable colour rings, voltage reduction adapter
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Fan Bearing
- Hydraulic bearing
- Rotation Speed
- 2350 rpm
- Air Flow
- 62.7 cfm
- Noise Level
- 35 dBA
- Rated Voltage
- 12 V
- Rubberised corners
- 200 g
- 2-year warranty
- Product Type
- Case fan
- Package Content
- 200 g
Heatsink & Fan
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Fan Bearing
- Hydraulic bearing
- Rotation Speed
- 2350 rpm
- Air Flow
- 62.7 cfm
- Air Pressure
- 3.1 mm
- Noise Level
- 35 dBA
- Rated Voltage
- 12 V
- Rated Current
- 0.18 A
- Limited warranty: - 2 years
