Product
Corsair Air Series AF120 Performance Edition (Double Pack)
Quicklinx: 887MWS00 Mfr#: CO-9050004-WW
The Air Series AF120 fans let you have it all. Nine ultra-thin, custom-molded blades push ample air volume. Rubber corners dramatically reduce vibration. The advanced hydraulic bearing system is quiet and reliable, and you can customize the look with the three included colored rings.
AF models performs best in unrestricted spaces with at least 3cm of clearance, and they're ideal for mounting at the rear or top of your PC case as exhaust fans for your PC's motherboard and CPU, graphics accelerators, and other components Filling the case with heat. They work equally well for unrestricted intake fans, for areas like side panels or bottom intakes.
CORSAIR Air Series AF120 Performance Edition - case fan
Case fan
Packaged Quantity
2 (specifications are for single item)
Package Content
Mounting screws for case fans, 3 replaceable colour rings, voltage reduction adapter
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Hydraulic bearing
Rotation Speed
1650 rpm
Air Flow
63.5 cfm
Noise Level
30 dBA
Rated Voltage
12 V
Rubberised corners
200 g
2 years warranty
Packaged Quantity
Case fan
Package Content
200 g
Heatsink & Fan
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Hydraulic bearing
Rotation Speed
1650 rpm
Air Flow
63.5 cfm
Air Pressure
1.1 mm
Noise Level
30 dBA
Rated Voltage
12 V
Rated Current
0.13 A
Rubberised corners
