Product
Corsair Air Series 140mm Quiet Edition High Airflow Fan - AF140 Purp
Quicklinx: 9493WS00 Mfr#: CO-9050017-PLED
Type: Case Fan
Hurry, only 3 left in stock!
£12.03 ex VAT
£14.43 inc VAT
Corsair Air Series LED high airflow PC case fans combine efficient, low-noise airflow with striking LED lighting. The custom-molded blades are designed for high-volume air delivery with less noise and turbulence than typical case fans. They're translucent, with a frosted texture, so the light from the four LEDs adds a dramatic effect.
Air Series AF fan models perform best in unrestricted spaces with at least 3 cm of clearance, and they're ideal for mounting at the rear or top of your PC case as exhaust fans for your PC's motherboard and CPU, graphics accelerators, and other components that fill the case with heat. They work equally well as unrestricted intake fans for areas like side panels or bottom intakes.
  • Superior cooling performance and LED illumination
  • Tuned for high-airflow, large volume cooling
  • Better performance than standard case fans
    Air Series AF fan models are designed to outperform standard case fans. The blades are custom-molded for optimal airflow, and they're ultra-thin for less noise and turbulence. The sleeved bearing system reduces vibration for quiet operation.
CORSAIR Air Series LED AF140 Quiet Edition - case fan
Case fan
Package Content
Mounting screws for case fans
Purple
Fan Diameter
140 mm
Fan Height
25 mm
Fan Bearing
Sleeve bearing
Rotation Speed
1200 rpm
Air Flow
66.4 cfm
Noise Level
25.5 dBA
Power Connector
3-pin plug
Rated Voltage
12 V
Purple LED x4, custom-molded fan blades
160 g
2 years warranty
Case fan
Package Content
160 g
Purple
Heatsink & Fan
Fan Diameter
140 mm
Fan Height
25 mm
Fan Bearing
Sleeve bearing
Rotation Speed
1200 rpm
Air Flow
66.4 cfm
Air Pressure
0.8 mm
Noise Level
25.5 dBA
Power Connector
3-pin plug
Rated Voltage
12 V
Operation Voltage
7 - 12 V
Rated Current
0.23 A
Type: Case Fan
Brand: Corsair
Price Range Ex VAT: 0 - 50
