Corsair Air Series LED high airflow PC case fans combine efficient, low-noise airflow with striking LED lighting. The custom-molded blades are designed for high-volume air delivery with less noise and turbulence than typical case fans. They're translucent, with a frosted texture, so the light from the four LEDs adds a dramatic effect.
Air Series AF fan models perform best in unrestricted spaces with at least 3 cm of clearance, and they're ideal for mounting at the rear or top of your PC case as exhaust fans for your PC's motherboard and CPU, graphics accelerators, and other components that fill the case with heat. They work equally well as unrestricted intake fans for areas like side panels or bottom intakes.
Superior cooling performance and LED illumination
Corsair Air Series LED high airflow PC case fans combine efficient, low-noise airflow with striking LED lighting. The custom-molded blades are designed for high-volume air delivery with less noise and turbulence than typical case fans. They're translucent, with a frosted texture, so the light from the four LEDs adds a dramatic effect. -
Tuned for high-airflow, large volume cooling
Air Series AF fan models perform best in unrestricted spaces with at least 3 cm of clearance, and they're ideal for mounting at the rear or top of your PC case as exhaust fans for your PC's motherboard and CPU, graphics accelerators, and other components that fill the case with heat. They work equally well as unrestricted intake fans for areas like side panels or bottom intakes. -
Better performance than standard case fans
Air Series AF fan models are designed to outperform standard case fans. The blades are custom-molded for optimal airflow, and they're ultra-thin for less noise and turbulence. The sleeved bearing system reduces vibration for quiet operation.
- CORSAIR Air Series LED AF120 Quiet Edition - case fan
- Product Type
- Case fan
- Packaged Quantity
- 2 (specifications are for single item)
- Package Content
- Mounting screws for case fans
- Blue
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Fan Bearing
- Sleeve bearing
- Rotation Speed
- 1500 rpm
- Air Flow
- 52.19 cfm
- Noise Level
- 25.2 dBA
- Power Connector
- 3-pin plug
- Rated Voltage
- 12 V
- Blue LED x4, custom-molded fan blades
- 250 g
- 2-year warranty
- Packaged Quantity
- Product Type
- Case fan
- Package Content
- 250 g
- Blue
Heatsink & Fan
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Fan Bearing
- Sleeve bearing
- Rotation Speed
- 1500 rpm
- Air Flow
- 52.19 cfm
- Air Pressure
- 0.75 mm
- Noise Level
- 25.2 dBA
- Power Connector
- 3-pin plug
- Rated Voltage
- 12 V
- Operation Voltage
- 7 - 12 V
- Rated Current
- 0.4 A
- Limited warranty: - 2 years
