Your basket is empty
Corsair 8GB (2x4GB) DDR3 1866Mhz CL9 Vengeance Blue Performance Desktop Memory Kit
Quicklinx: 86LMWS00 Mfr#: CMZ8GX3M2A1866C9B
Corsair Vengeance memory modules are designed with overclockers in mind. Vengeance DIMMs are built using RAM specially selected for their high-performance potential. Aluminum heat spreaders help dissipate heat, and provide the aggressive look that you want in your gaming rig.
Corsair Vengeance - DDR3 - 8 GB: 2 x 4 GB - DIMM 240-pin
RAM memory
8 GB: 2 x 4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1866 MHz (PC3-15000)
Latency Timings
CL9 (9-10-9-27)
Intel Extreme Memory Profiles (XMP), dual channel, Vengeance heatspreader, unbuffered
Voltage
1.5 V
8 GB: 2 x 4 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL9 (9-10-9-27)
Non-ECC
Voltage
1.5 V
Compatible Slots
2 x memory - DIMM 240-pin
