Corsair 8GB (2x4GB) DDR3 1600Mhz CL9 XMS3 Performance Desktop Memory Kit
Quicklinx: 75H5WS00 Mfr#: CMX8GX3M2A1600C9
The XMS3 family is Corsair's mainstream line of performance DDR3 memory. These modules allow users to experience outstanding memory performance and stability.
Key Features
  • Maximize your system memory capacity for ultimate performance
  • Guaranteed to work on all dual channel Intel and AMD platforms
  • XMS heat spreader
  • World famous Corsair reliability and performance
Package Contents
  • Two 4GB memory modules
  • Designed for use with all DDR3 motherboards with two memory channels
  • Warranty: Lifetime
  • Size: 8GB Kit (2 x 4GB)
  • Performance Profile: XMP
  • Fan Included: No
  • Heat Spreader: XMS
  • Memory Configuration: Dual Channel Memory
  • Type: DDR3
  • Package - Memory Pin: 240
  • Package - Memory Format: DIMM
  • Tested Voltage: 1.65
  • SPD Voltage: 1.5
  • Speed Rating: PC3-12800 (1600MHz)
  • SPD Speed 1333MHz
  • Tested Speed 1600Mhz
  • Tested Latency 9-9-9-24
  • SPD Latency9-9-9-24
CORSAIR XMS3 - DDR3 - kit - 8 GB: 2 x 4 GB - DIMM 240-pin - 1600 MHz / PC3-12800 - unbuffered
Memory kit
8 GB: 2 x 4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MHz (PC3-12800)
Latency Timings
CL9 (9-9-9-24)
Heat sink, dual channel, unbuffered
Voltage
1.65 V
8 GB: 2 x 4 GB
Upgrade Type
Generic
DRAM memory kit
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL9 (9-9-9-24)
Non-ECC
Voltage
1.65 V
Compatible Slots
2 x memory - DIMM 240-pin
