Corsair high performance Vengeance memory module 8GB (2x4GB) 1600MHz 9-9-9-24, 1.5V for motherboards using AMD, Intel dual channel platforms. These Vengeance modules are designed for high-performance systems with extra-large CPU coolers, small form factor system builds, or other space-constrained applications that prevent the use of standard Vengeance memory. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
- 8GB (2x4GB) DDR3 for AMD, Intel Dual processors
- 1600MHz
- 9-9-9-24 latency
- Vengeance heat spreader for styling and performance
- 10 Years Warranty
Speciifcations
- Density: 8GB (2x4GB Module)
- Speed: 1600MHz
- Timing: 9-9-9-24
- Type: DDR3
- Format: DIMM
- Pin Out: 240
- Pin Voltage: 1.5V
- Warranty: 10 Years
Great looking, great overclocking memory
Corsair Vengeance memory modules are designed with overclockers in mind. Vengeance DIMMs are built using RAM specially selected for their high-performance potential. Aluminum heat spreaders help dissipate heat, and provide the aggressive look that you want in your gaming rig. -
Optimized for compatibility with the CPUs and motherboards
Vengeance memory is designed specifically for the latest CPUs. The 1.5V VDIMM spec ensures you get the performance you expect, even without increasing memory voltages.
- CORSAIR Vengeance - DDR3 - kit - 8 GB: 2 x 4 GB - DIMM 240-pin - 1600 MHz / PC3-12800 - unbuffered
- Product Type
- Memory kit
- Capacity
- 8 GB: 2 x 4 GB
- Memory Type
- DDR3 SDRAM - DIMM 240-pin low profile
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 1600 MHz (PC3-12800)
- Latency Timings
- CL9 (9-9-9-24)
- Intel Extreme Memory Profiles (XMP), dual channel, Vengeance heatspreader, unbuffered
- Voltage
- 1.5 V
- Limited lifetime warranty
- Capacity
- 8 GB: 2 x 4 GB
- Upgrade Type
- Generic
- DRAM memory kit
- Technology
- DDR3 SDRAM
- Form Factor
- Speed
- Latency Timings
- CL9 (9-9-9-24)
- Non-ECC
- Voltage
- 1.5 V
- Compatible Slots
- 2 x memory - DIMM 240-pin
