Corsair 8GB (2x4GB) DDR3 1600Mhz CL9 Vengeance Low Profile Black Performance Desktop Memory Kit
Quicklinx: 7JZ8WS00 Mfr#: CML8GX3M2A1600C9
Corsair high performance Vengeance memory module 8GB (2x4GB) 1600MHz 9-9-9-24, 1.5V for motherboards using AMD, Intel dual channel platforms. These Vengeance modules are designed for high-performance systems with extra-large CPU coolers, small form factor system builds, or other space-constrained applications that prevent the use of standard Vengeance memory. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
  • 8GB (2x4GB) DDR3 for AMD, Intel Dual processors
  • 1600MHz
  • 9-9-9-24 latency
  • Vengeance heat spreader for styling and performance
  • 10 Years Warranty
Speciifcations
  • Density: 8GB (2x4GB Module)
  • Speed: 1600MHz
  • Timing: 9-9-9-24
  • Type: DDR3
  • Format: DIMM
  • Pin Out: 240
  • Pin Voltage: 1.5V
  • Warranty: 10 Years
  • Great looking, great overclocking memory
    Corsair Vengeance memory modules are designed with overclockers in mind. Vengeance DIMMs are built using RAM specially selected for their high-performance potential. Aluminum heat spreaders help dissipate heat, and provide the aggressive look that you want in your gaming rig.
  • Optimized for compatibility with the CPUs and motherboards
    Vengeance memory is designed specifically for the latest CPUs. The 1.5V VDIMM spec ensures you get the performance you expect, even without increasing memory voltages.
CORSAIR Vengeance - DDR3 - kit - 8 GB: 2 x 4 GB - DIMM 240-pin - 1600 MHz / PC3-12800 - unbuffered
Memory kit
8 GB: 2 x 4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin low profile
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MHz (PC3-12800)
Latency Timings
CL9 (9-9-9-24)
Intel Extreme Memory Profiles (XMP), dual channel, Vengeance heatspreader, unbuffered
Voltage
1.5 V
8 GB: 2 x 4 GB
Upgrade Type
Generic
DRAM memory kit
DDR3 SDRAM
Speed
Latency Timings
CL9 (9-9-9-24)
Non-ECC
Voltage
1.5 V
Compatible Slots
2 x memory - DIMM 240-pin
