Corsair built its reputation on performance memory that shines in the most demanding computing situations: extreme gaming and high-transaction processing environments. But not all computers are put to such extreme usage. So we brought the same reliability, testing and Corsair quality to a line of memory designed to support standard computing situations such as popular office applications. Now it's one of our most popular memory lines. Backed with a lifetime warranty, it is memory you can rely on.
- 8GB Kit (2x4GB)
- DDR3 1333MHz DIMM
- 333MHz
- 9-9-9-24 latency
- 10 Year Warranty
- Density: 8GB Kit (2x4GB)
- Speed: 1333MHz
- Timing: 9-9-9-24
- Type: DDR3
- Format: DIMM
- Pin Out: 240 Pin
- Voltage: 1.5V
- Warranty: 10 Years
- CORSAIR Value Select - DDR3 - kit - 8 GB: 2 x 4 GB - DIMM 240-pin - 1333 MHz / PC3-10600 - unbuffered
- Product Type
- Memory kit
- Capacity
- 8 GB: 2 x 4 GB
- Memory Type
- DDR3 SDRAM - DIMM 240-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 1333 MHz (PC3-10600)
- Latency Timings
- CL9 (9-9-9-24)
- Unbuffered
- Limited lifetime warranty
- Capacity
- 8 GB: 2 x 4 GB
- Upgrade Type
- Generic
- DRAM memory kit
- Technology
- DDR3 SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- Latency Timings
- CL9 (9-9-9-24)
- Non-ECC
- Unbuffered
- Compatible Slots
- 2 x memory - DIMM 240-pin
