Corsair Mac Memory, 8GB 1066MHz C7 DDR3 SODIMM for Apple iMac, MacBook and MacBook Pro 4GB (2x4GB). Tested at Apples compatibility lab to ensure functionality with all current products that have official Apple support for 4GB SO-DIMMs. Adding system memory is one of the most effective ways to improve overall performance and Corsair's Mac Memory offers a solid tested solution with a limited lifetime warranty.
- Tested at Apple's compatibility lab to ensure functionality with all current products that have official Apple support for 4GB SODIMMs
- World famous Corsair reliability and performance
- Dual Channel
- DDR3 Memory
- 10 Year Warranty
- Density: 8GB (2x4GB SO-DIMM)
- Speed: 1066MHz CL7
- Timing: 7-7-7-20 (1066 MHz)
- Type: DDR3
- Format: SO-DIMM
- Pin Out: 204
- Pin Voltage: 1.5V
- Warranty: 10 Years
- CORSAIR Mac Memory - DDR3 - kit - 8 GB: 2 x 4 GB - SO-DIMM 204-pin - 1066 MHz / PC3-8500 - unbuffered
- Product Type
- Memory kit
- Capacity
- 8 GB: 2 x 4 GB
- Memory Type
- DDR3 SDRAM - SO-DIMM 204-pin
- Upgrade Type
- System specific
- Data Integrity Check
- Non-ECC
- Speed
- 1066 MHz (PC3-8500)
- Latency Timings
- CL7 (7-7-7-20)
- Unbuffered
- Voltage
- 1.5 V
- Limited lifetime warranty
- Capacity
- 8 GB: 2 x 4 GB
- Upgrade Type
- System specific
- DRAM memory kit
- Technology
- DDR3 SDRAM
- Form Factor
- SO-DIMM 204-pin
- Speed
- Latency Timings
- CL7 (7-7-7-20)
- Non-ECC
- Unbuffered
- Voltage
- 1.5 V
- Compatible Slots
- 2 x memory - SO-DIMM 204-pin
