The Value Select line provides quality, tested, compatible desktop memory at competitive prices. The Value Select line is qualified for major current desktop and laptop systems.
- CORSAIR Value Select - DDR3L - module - 8 GB - SO-DIMM 204-pin - 1600 MHz / PC3-12800 - unbuffered
- Product Type
- Memory module
- Capacity
- 8 GB
- Memory Type
- DDR3L SDRAM - SO-DIMM 204-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 1600 MHz (PC3-12800)
- Latency Timings
- CL11 (11-11-11-28)
- Low Voltage, unbuffered
- Voltage
- 1.35 V
- Limited lifetime warranty
- Capacity
- 8 GB
- Upgrade Type
- Generic
- DRAM memory module
- Technology
- DDR3L SDRAM
- Form Factor
- SO-DIMM 204-pin
- Speed
- Latency Timings
- Non-ECC
- Voltage
- 1.35 V
