Corsair 850W HX Series HX850 80 Plus Platinum Fully Modular PSU
Quicklinx: CVXJWS00 Mfr#: CP-9020138-UK
CORSAIR HX series power supplies give you extremely tight voltage regulation, quiet operation, Platinum-certified efficiency, and a fully modular cable set. Built with all Japanese 105°C capacitors, they're a great choice for high performance PCs where reliability is essential.
  • Quiet, efficient operation
    80 PLUS Platinum efficiency reduces operating cost and excess heat, and Zero RPM fan mode ensures virtual silence at low and medium loads.
  • 100% Japanese 105 °C capacitors
    Premium internal components ensure solid power delivery and long term reliability.
  • Zero RPM fan mode
    Since the fan doesn't turn on until it's needed, you'll enjoy virtually silent operation at low and medium loads.
  • Power in your hands
    Toggle single +12 V rail or multi +12 V rail mode. In the "SINGLE" position, the full output capability of the power supply's +12 V rail is available to any and all connectors, while in the "MULTIPLE" position, each individual connector has Over-Current Protection so no more than 40 A of current can be delivered on any given cable.
  • Easy installation
    The fully modular DC cables make builds and upgrades easy, with clean, great-looking results.
CORSAIR HX Series HX850 - power supply - 850 Watt
Power supply - internal
Specification Compliance
ATX12V 2.4/ EPS12V 2.92
80 PLUS Certification
80 PLUS Platinum
1.95 kg
United Kingdom
Input Voltage
AC 100-240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
850 Watt
Output Current
+3.3V - 25 A , +5V - 25 A , +12V - 70.8 A , -12V - 0.8 A , +5VSB - 3 A
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 2 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 6 x 8 pin PCI Express power with detachable 2 pin section , 6 x 4 PIN internal power , 8 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector
Modular Cable Management
Cooling System
135 mm fan
Case badge, cable ties, mounting kit
15 cm x 18 cm x 8.6 cm
10 years warranty
PSU Form Factor
ATX
United Kingdom
Input Voltage
AC 100-240 V
Frequency Required
47 - 63 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
850 Watt
Output Current
80 PLUS Platinum
Power cable kit
Cooling System
135 mm fan
Sleeved cables, over voltage protection, overpower protection, undervoltage protection, short-circuit protection, temperature controlled fan, Zero RPM fan mode, fluid dynamic bearing cooling fan, switchable single/multi 12V rails, temperature sensor, fully modular
CSA, UL, TUV, C-Tick, cUL, CB, FCC, RoHS, WEEE, ICES, REACH, KC, China RoHS, RCM, CU
Limited warranty - 10 years
15 cm
18 cm
8.6 cm
1.95 kg
Shipping Width
22.5 cm
Shipping Depth
39.2 cm
Shipping Height
15.2 cm
Shipping Weight
3.95 kg
