Corsair 850W CX850M Modular Series 850 Watt ATX 80 PLUS Bronze PSU
Quicklinx: 9XNSWS00 Mfr#: CP-9020099-UK
CX Series Modular power supply units are an excellent choice for basic system builds and desktop PC computer upgrades, offering high reliability, low noise, easy installation. The flexible modular cabling system lets you use only the cables you need, and 80 PLUS Bronze certified efficiency means less excess heat, lower noise, and lower power bills. The large-diameter, thermally controlled fan makes CX Series Modular quieter at idle, and the large diameter reduces noise even when you're pushing your system hard. And, the matte black finish, black-sleeved cables and black connectors help give your system a restrained, high-tech look.
  • Modular cabling system lets you use only the cables you need
  • 850W Continuous power with 80 PLUS Bronze certified efficiency for low noise and lower power bills
  • Built and tested to strict standards for trouble-free installation and smooth operation
  • Over-voltage and over-power protection, under-voltage protection, and short circuit protection provide maximum safety to your critical system components.
  • Extra long fully-sleeved cables support full tower chassis.
Box Contains
1 x CX850W PSU and Cables
  • Faster installation and better-looking builds
    The modular cabling system lets you use only the cables you need. You get to save space and reduce clutter for a cleaner-looking build and improved airflow.
  • Reliable and compatible
    CX Series Modular is built and tested to strict standards for trouble-free installation and smooth operation.
  • Low noise
    80 PLUS Bronze certified efficiency and clever fan design allow for little or no detectable fan noise during regular operation.
  • Good looks
    The matte black finish, black-sleeved cables and black connectors help give your system a restrained, high-tech look.
  • Corsair engineering and quality control
    Every Corsair power supply is designed by our California engineering team and built to the exact specifications. The same care that goes into the design and testing of our renowned high-power enthusiast power supplies also goes into the CX Series Modular, because you need confidence and reliability regardless of your build budget.
    Since the peripheral power cables aren't hard-wired to the power supply, you can connect only the cables you need for your exact configuration of PCI-E cards and storage devices. The rest of the cables stay in the box, and not in your PC's case where they can add to the clutter and interfere with airflow.
  • Large-diameter, thermally controlled fan
    Once you've installed a PSU, you shouldn't have to think about it. Employing a thermally controlled fan makes the CX Series Modular quieter at idle, and the large diameter reduces noise even when you're pushing your system hard.
CORSAIR CX-M Series CX850M - 2015 Edition - power supply - 850 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.3/ EPS12V 2.91
80 PLUS Certification
80 PLUS Bronze
3.27 g
United Kingdom
Input Voltage
AC 100-240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
850 Watt
Output Current
+3.3V - 25 A , +5V - 25 A , +12V - 70 A , -12V - 0.8 A , +5VSB - 3 A
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 4 x 8 pin PCI Express power with detachable 2 pin section , 6 x 15 pin Serial ATA power , 6 x 4 PIN internal power , 2 x 4 PIN mini-power connector
Modular Cable Management
Cooling System
140 mm fan
Matte black
15 cm x 16 cm x 8.6 cm
3-year warranty
PSU Form Factor
ATX
Matte black
United Kingdom
Input Voltage
AC 100-240 V
Input Voltage Range
AC 90 - 264 V
Frequency Required
47 - 63 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
850 Watt
Output Current
Efficiency
85%
80 PLUS Bronze
MTBF
100,000 hours
Cooling System
140 mm fan
Sleeved cables, over voltage protection, overpower protection, undervoltage protection, short-circuit protection, single 12V rail, temperature controlled fan, semi-modular
Energy-Related Products (ErP) Lot 6
Limited warranty - 3 years
15 cm
16 cm
8.6 cm
3.27 g
Shipping Width
29 cm
Shipping Depth
21.6 cm
Shipping Height
13 cm
Shipping Weight
3.53 kg
